Where did the sun go?
Upgraded to the latest version 4.9 and I cannot find the Sun in Iray settings, was it removed for some reason?
  • R25SR25S Posts: 595
    Do you mean this one (right at the bottom of the render settings)?
    498 x 1031 - 87K
    This is a modal selection. You have to select Sun-Sky in the Environment Mode dropdown in the Environment tab. Then the Sun-Sky adjustments appear. As far as I remember, this didn't change from 4.8 to 4.9.
