Adding to Cart…
I have submitted it as Request #209663.
Thanks.
So... with release imininent, are we going to start seeing faster speeds out of Connect? Biggest issue for me has been Connect not showing me products for 24 hours or more after purchase, and sometimes being very selective about what products to show me (like not showing me a texture set was available until I actually had the item loaded and the context filter set).
Have to say I'm anxiously awaiting the release but I'm impressed about the team taking their time with this release. Not sure if this is the last release of the 4.X but in any case take your time, I want it as bug free as possible.
hmm I wonder if this is related:
I noticed that for some reason I do not automatically login after starting DAZ Studio.
In some past Beta version the login window was displayed at start after the welcome window.
Now I always seem to have to manually click on "login" in the upper right corner of the Smart Content Tab.
Because of that it happend a few times that I was searching for updates or available products without actually noticing that I was still in the "work offline" mode...
I did search around in the preferences but I could actually not find any
Settings to choose if you automatically log in at start up or not
Is there such a setting allready and I simply am looking in the wrong place?
Or
Is that option not (yet) available?
When trying to load G3F in a new scene recently I got a odd error message.
"Error reading file, see log for more details". message.
But when looking in log to see the details, it just says "Error reading file, see log for more details".; which is not helpful.
This happened after I updated the Beta to 4.9.0.61. G3F always loaded fine before.
Oddly when I load G3M it loads ok. Both load ok in 4.8. And worked prior to 4.9.0.61.
I suspect it has something to do with DAZ Connect/cloud, which has been more aggrevating than useful so far.
BTW, Win 7 64 bit ; Nividia GT 730
I submited a ticket #209466 and got some suggestions to try from the support person, but they have not worked so far.
It was working in an earlier DS4.9 beta?
If it is any help, tho not the same. I get that when I go to put a material preset on something, and Not notice that Nothing is selected in the scene tab.
Oddly, we have the same specs. I have 4.9.0.61 Public Build, and G3F loads fine in that. I did install G3F using DIM (I did not use that 'Connect' thing for anything), tho I'm not sure if that matters or not.
Oh, thought. That 'Content Directory Manager' thing. The order that the listings of paths is in, is that important or not?
It makes no difference.
YES. as I said " And worked prior to 4.9.0.61."
I suspected that somehow the G3F duf file had become corupted, so I uninstalled and reinstalled the G3F Starter Essentials via DIM. That didn't help.
I haven't heard anymore from DAZ support yet. And since 4.9.0.63 has been released as the General release I guess that this issue may seem irrelevant now. But I don't feel secure in overwriting 4.8 with this 4.9.0.63 because of the problems first users are reporting.
Edit: I did recieve more responses from DAZ CS but nothing suggested worked. However I was able to resolve the problem by finding corrupted G3F files in the cloud folder. Deleting those fixed the problem. Apparently they got corrupted during the DAZ Connect download and the files were only partially downloaded and never removed causing that weird error message.
Now, G3F loads fine from both cloud and locally. But there are still issues with Smart Content not working very well as many other people are also reporting in the Forums.
I noticed that a new set of 4.9 Beta files appeared in my DIM a couple of hours ago. What version is this? Is it a real update?
Same as the release version. (4.9.0.63)
Thanks for the speedy reply - excellent news for me as I'd like to upgrade my Beta installation to try out the new Iray version etc, but I'm not keen (yet) to wipe out my DS4.6 till I'm sure all my plugins and 3Delight light sets are working in 4.9.
So this gives us the equivalent of having both release versions of 4.8 and 4.9 at the same time on the PC? Yes?
Yes, this way you can have both installed.
Well, that's nice but doesn't help the people who already overwrote their 4.8 version to upgrade (not me). And why would they put an identical version in the Beta DL spot unless it is to respond to the clamor over the problems some people are having. A Beta is supposed to be a hypothetical improvement over the previous version, not the same ( altho, as we know all too well, newer is NOT always better).
