HOW TO LOAD THE ARGUMENTED REALITY INTO REALITY LUXRENDER
Dearest,
I ordered the argumented reality light compilation and it was installen into Daz 4.9 through DIM.
I thought I could load a scene into the daz, deactivate all light sources and then just double click on the argumented reality light .dsa in the content tab of DAz 3d and then open / start up the REALITY RENDER EDITER and hit 'render'. I assumed the reality plugin would render the scene with the selected .dsa light sources but after clicking on the .dsa file a message shows up (see attachement) stating that the 'reality toolkit was not found 'and that the render script will be stopped/closed.
Now , how can I use these .dsa files with Reality? I also cannot find a way to impost these .dsa files into Reality/Luxrender.
Anyone that does know how to get this working?
Many thanks in advance
Cheers
Peter
  • evilded777evilded777 Posts: 2,543
    Those are pretty old.  I think the light format has changed since the version of Reality that those were designed for.  Now, this is just me thinking outloud here, I'm not positive this is the case because I don't own the Augmented Reality lights...but I know things have changed.  I think those might work in Reality 2... but I don't think they are gong to work in Reality 4.  At least not as a one click solution.  You can still load the HDRI files by hand... but that's not much consolation.
  • Those are pretty old.  I think the light format has changed since the version of Reality that those were designed for.  Now, this is just me thinking outloud here, I'm not positive this is the case because I don't own the Augmented Reality lights...but I know things have changed.  I think those might work in Reality 2... but I don't think they are gong to work in Reality 4.  At least not as a one click solution.  You can still load the HDRI files by hand... but that's not much consolation.
    Okay , thanks ,but that would be a real low.......selling stuff no more compatable/outdated....
     I'll just ask support......
    Thnks.
