Mannequin for Genesis 3 Female - some questions
cosmo71
I have some questions to the Mannequin for Genesis 3 Female product:
1. Is it possible to add G3F textures or is this not possible because of a different UV or so?
2. Can morphs of G3F used on the mannequins so that the mannequin looks like an own chreated character?
Post edited by cosmo71 on
I've managed to change the texture but only by using a jpg file.
I've also posed the mannequin, but not tried any morphs as yet.
Just tried with the Upper Thighs and Middle Shoulders attachments. The default UV's on the geograft don't seem to use the figure's textures. The closest you might get is with a skin-like noise image...a figure-generic or anime texture can work if it doesn't have blank spaces.
Morphs seem to translate fine but note that some (I tried Skyler and Josie to test something that would be obvious) slide the mesh in ways that will leave the caps of a cut-off mannequin part in choppy zig-zags.
Skyler morph below with default G3F Arms texture copy and pasted to the Mannequin arms; seam is obvious due to the UV mismatch.
The first thing that I did after purchasing the mannequin was to crank in some morphs. They act on the body with no problem, and they even affect the geografted head satisfactorily. Thus, when I dial in Arki's Rune Head 2 morph, the geograft roughly follows the shape of her features. See attached picture [also showing creepy overlays that I will be releasing as a freebie!]. Hope this helps.
--MW
I bought this too sadly you can't use crossfigure to add male compatability but it works ok i you use the male shape from Cross-figure, too bad they don't have other stand options included, but the one that is part of Mindvision G.D.S products should work.
Posing and morphing of characters is ok, the mannequin just do not accept the character materials.
Below is a render of Taia:
http://www.daz3d.com/fwsa-taia-hd-for-victoria-7
Hoping someone can adapt this, so that we can have a modern version of Raw Art's 'Severed Man' product!
http://www.daz3d.com/severed-man
That would be great, but I'm not holding my breath. Especially not for the DAZ shop.
