I NEED HELP WITH A DIM D/L OF LAMH!!
Saphirewild
in New Users
I got the free version of the LAMH but it does not have a check mark beside it in the installed side of the DIM is there something I can do about that?
That's not an issue - the check mark indicates that theer is content with metadata in the package, so that it will show in Smart Content/Categories. Since this is simply a plug-in it doesn't ahve content or metadata.
So how do you open the thing in daz like I was told you could?
I can not find it in daz at all!! or am I looking in the wrong place???
Oops, sorry - I just noticed you did say which version you are using. The lack of a check mark is right - that indicates that the item has metadata ("Smart Content") but the player is just a plug-in, no content. I'm not sure how the free palyer works, I think you simply load a figure/character preset for an item with hair. Note that you do need to render using 3Delight to see more than the guide hairs.
Window>Panes>LAMH
TYSM Packmaster1958 it worked that way!!!!
