dealing with poses that change shape
was wondering how one deals with poses that will change your dialed morphs to a default shape
 I only noticed this with some G3F freebie Poses I recently picked up.
I was just thinking, not sure if it would work, but if I saved shape as Preset, then use the pose, then use the preset to get my dialed morphs back.  (Actually just thought that while typing this) think I try that later
but really was wondering if there was a setting I may need to do to stop  the resizing happening ?
I wouldn't have a problem, if need be, saving poses and doing what ever I need to do stop the resizing.
Suggestions  or ideas ?  . . .and no longer have Petite characters is not a option wink
  • FistyFisty Posts: 3,416
    If a pose is changing shaping dials it means the pose wasn't saved correctly, you'd need to resave the pose and make sure all the shaping boxes are unchecked to keep it from happening again.
  • XaatXuunXaatXuun Posts: 880
    Strange, now when I use the pose, the Morphs stays. Maybe after closing DAZ Studio something happens that fixes it
    I'm going to see what happens if I create a new character, and see if it only happens then.
    well that wasn't it,  I dialed a new character, first was zero pose, second was a pose that dosen't change scaling, third was a pose that does change scale.
    then I closed and re-launched DAZ,  to see if that would work, nope still rescales. So that thought didn't work, then I was thinking maybe save in the pose that does work then close and relaunch . . that's next after I press Post Comment . .
    since I went back earlier and now can use the poses on the first one, and now she doesn't rescale, maybe  on my last save  I was in a pose that worked . .  I forgot to look for where I need uncheck any shaping boxes,  I just use dials, no presets.
    1000 x 997 - 275K
    1000 x 997 - 258K
    1000 x 997 - 277K
