G3F No-Suit [commercial]
2»
  • vadimtvadimt Posts: 33
    Thank you @riftwitch. I played with it a little - copy all the morphs and textures from an original figure, and then use the No-Suit mat zones. Works fine.
  • riftwitchriftwitch Posts: 1,439
    Glad I could help. The first time I used the G3F version, I was a bit stumped at first, but I eventually got it right. I haven't picked up the G3M version yet, but it's in my wishlist.
  • GnotMeGnotMe Posts: 131
    I like your products but the No Suit for Gen 3 has me stumped. I'm trying to use it with V7.  Would someone please give step by step instructions on how to use it.
    I assumed the suit would conform to the character but I simply end up with a mess the Genesis 3 female interspersed with V7 who is taller and skinnier. Nothing I try makes any difference. I'm really frustrated that I have been unable to find any instructions, or tutorial anywhere.
    Thanks,
    Dan
  • Pack58Pack58 Posts: 750
    edited January 2016
    I just load RawArts "No Suit MAT-Zone Figure" and select it then load any G3F skin texture from smart content "Materials" then apply the corresponding full body morph from the parameters tab.
    Edit: then you can replace any of the new material zones with whichever shader/texture you want. Plus use the new morphs to simulate a bodysuit/leggings/gloves etc.
    Post edited by Pack58 on
  • RawArtRawArt Posts: 6,134
    The no suit does not conform to any figure...it is NOT a suit, or outfit of any kind. Hence the name "No-Suit".
    The No-Suit is simply morphs that get applied to your base figure to give the appearance of someone wearing a body suit.
    From the product description " The No Suit is a series of morphs (Low and High definition) made for Genesis 3 Male that will instantly make him appear to be wearing tight fitting spandex.  "
    You load the included new G3 figure from my folder. This figure is exactly the same as your regular G3 figure, except it has new material zones that correspond to the material presets I included. You can apply all your other usual character morphs and textures directly onto this figure. You just dial in the no-suit morphs that you want, and apply the material presets you want.
