mcjCornerWall : New Morphing Poser Prop Freebie !
mCasualmCasual Posts: 4,607
edited December 2015 in Freebies
https://sites.google.com/site/mcasualsdazscripts6/mcjcornerwall
there's 7 morphs to adjust everything
one of the goals was to have "welded" corners, because when using separate Planes,
it's hard to keep it "air-tight" and even when your planes meet perfectly, the renders may let light through
I dont know if the earlier versions of DS4.5 $.8 have it, but the wood and stucco shaders in my deonstration scenes are in
My DAZ 3D Library\Shader Presets\Iray\NVIDIA MDL Examples
Post edited by mCasual on
  • DigiDotzDigiDotz Posts: 515
    A why havent I got something like that already moment.
    Thanks!
    cough -respun animation file- end cough
  • Oso3DOso3D Posts: 15,115
    Very nice, thank you so much!
    Your service to the community is really appreciated.
  • SkelchSkelch Posts: 276
    Thank you for this I know this will be most useful
  • mCasualmCasual Posts: 4,607
    also note that there was and still is a CornerRoom prop right ... here
    https://sites.google.com/site/mcasualsdazscripts4/mcjcornerroom
    initially the CornerWall prop was created for this scene in 2012
    800 x 450 - 53K
  • Tim NTim N Posts: 193
    Thanks for this.
    (Just a small point: I had to spin the wall prop 180 degrees on the Y-axis to see the correct side.)
    welcome
    yes the load-time orientation is a bit annoying
    i found it after creating the morphs
    it was part of a scene and Aiko was wearing a static dress, she couldn't move an inch from that side of the wall
    if i spin the  .obj geometry 180 degrees i guess it would invert the morphs
    .... well ... ok i'll make a new version and announce it here when ready
    i think i'll make it be a different prop with a different name to avoid issues with saved scenes ( and Daz Studio data caches )
    also i'd like a version with subD molding/baseboard
    Tim N said:
    Thanks for this.
    No need to go to all that trouble on my behalf.
    When a nice prop like this one is free, I'm quite willing to spin it around. smiley
    ok but but but
    if you want a quick DIY fix
    open Runtime\libraries\props\mcasual\mcjCornerWall.pp2 in notepad or wordpad
    around line 145 you will find a section that reads
    		rotateY yRotate			{			name Y Rotate			initValue 0			hidden 0			forceLimits 0			min -100000			max 100000			trackingScale 1			keys				{				static  0				k 0 0				}			interpStyleLocked 0			}
     change it to
    		rotateY yRotate			{			name Y Rotate			initValue 180			hidden 0			forceLimits 0			min -100000			max 100000			trackingScale 1			keys				{				static  0				k 0 180				}			interpStyleLocked 0			}
    Fantastic! Great trick. Thanks.
    I understand the change to initVal, but what's the "k 0 180" line doing if you don't mind me asking?
    the K lines are animation keys
    so k 0 180
    means YRotate gets a keyframed value of 180 at frame 0
    i tried with just the initVal ... but since we had k 0 0, this was not enough
    the initVal 180 does insure that if you do a "Zero Transforms" or a "Zero Selected item" Y Rotate will be set to 180
    Got it. Thanks.
    Happy holidays to you. laugh
     Welcome, Happy Holidays !
    i think since you messaged here you'll be notified when i post upfates here
    for instance i may add wall-crown and a baseboard prop
    with the same morphs as the wall, this way you can copy and paste the wall settings and everything will fit
    Tim N said:
    Got it. Thanks.
    Blender-Cycles  (re) render of a 2012 Daz Studio Scene
    i'll try it in iRay
    1920 x 1080 - 194K
    So the UV mesh flows around corners? That may solve some basic issues I've had with walls and corners... heh.
  • MilosGulanMilosGulan Posts: 1,991
    Ok. This is great. I will wait for update :). Might be very useful. Now I need to download and try that script for elevation ground. I really need to learn to use it and other things :). Thank You.
    The elevate thing is amazing!
    as promised an iRay Render, though it's the original wall prop ... dont know if i subD'd the molding
    in fact i should try to subD the wall and see if it survives subD ... yes it does ... as long as you set the prop's subD tweakings correctly, else the walls wont render at all when dubD'd
     there's also the mcjWarp plugin, which is more complicated to use but lets you 3d-sculpt with your mouse
    i didnt try it recently though so i cant say if it still works with DS4.8
    http://www.daz3d.com/forums/discussion/21044/mcjwarp-sculpting-plugin-for-ds-4-5-pc-win-x32-x64-version-available
