CLEAR OR RESET TIMELINE
dash2128
What's the simplist way to clear an animated TIMELINE of an animation, so as to start over with the same loaded set of characters and props?
When creating an animation, it should be a simple matter just to clear what was animated, so as to start over- especially for a beginner, who is practicing,
Deleting the keypoint doesn't always seem to do it. (Am I overlooking a simple control that clears the timeline of the animation, but not the props, charecters and set?)
Post edited by Chohole on
On the main toolbar click Edit>Figure>Clear Animation for several more options.I think "clear figure pose" is the one you are after.
:) hope this helps
THANKS!
THAT WORKED!
Selecting the character twice (directly, tiill CLEAR ANIMATION appeared, did it, also; ...which I discovered becuase of your advice.
IN 4.6, I believe you can select a character, and click CLEAR SELECTION.
