CLEAR OR RESET TIMELINE
dash2128dash2128 Posts: 736
What's the simplist way to clear an animated TIMELINE of an animation, so as to start over with the same loaded set of characters and props?
When creating an animation, it should be a simple matter just to clear what was animated, so as to start over- especially for a beginner, who is practicing,
Deleting the keypoint doesn't always seem to do it.  (Am I overlooking a simple control that clears the timeline of the animation, but not the props, charecters and set?)
1383 x 262 - 42K
Post edited by Chohole on
  • IceCrMnIceCrMn Posts: 2,334
    On the main toolbar click Edit>Figure>Clear Animation for several more options.I think "clear figure pose" is the one you are after.
    :) hope this helps
  • dash2128dash2128 Posts: 736
    edited December 2015
    THANKS!
    THAT WORKED!
    Selecting the character twice (directly, tiill CLEAR ANIMATION appeared, did it, also; ...which I discovered becuase of your advice.
    IN 4.6, I believe you can select a character, and click CLEAR SELECTION.
    Post edited by dash2128 on
