New Year, New Sales Thread: Report Issues Here 4 "Reporting Only"
1…94969899100
  • ElorElor Posts: 4,272
    miladyderyni_173d399f47 said:
    Is the MORE-CHOICES code for an extra bundle for Premier still active, &, if so, would it be valid if I bought a membership now?
    It's still in my message so should be active (but I have already used it so I can't check).
    I don't know if it'll be active for people subscribing now.
  • Charlie JudgeCharlie Judge Posts: 13,687
    edited October 23
    Wasteland Outfit Bundle for Genesis 9 lists the file format as FBX but the individual products are in duf format.
    Post edited by Charlie Judge on
  • Angel_XAngel_X Posts: 107
    edited October 23
    Hi!
    I need some help. I have 15 "punches" [loyalty points/credits], and there is a 55% discount.
    I added the "Angor 9 Character Bundle" to my cart; the page shows $48.99, but in my cart, it’s $31.49.
    The math doesn't add up for me, because $48.99 minus 15% should be $22.05.
    Could you tell me if I’m calculating something wrong?
    https://i16.servimg.com/u/f16/13/60/30/33/angus_10.png
    https://i16.servimg.com/u/f16/13/60/30/33/incart10.png
    https://i16.servimg.com/u/f16/13/60/30/33/15_pun10.png
    Post edited by Angel_X on
    ... Problems with other things too like you see in this screenshot
    https://i16.servimg.com/u/f16/13/60/30/33/incart11.png
  • jmucchiellojmucchiello Posts: 2,771
    Somethng is off. I have 18 punches. So I should get $99.99 * 55% * 60% = $99.99 * (1-.55) * (1-.60) = $99.99 * 0.45 * 0.4 = $18.00 (82% off).
    But in my cart, it says: $99.99 21.72 78% Off
    Good thing I'm not actually buying it. But something isn't right. (And even it I had one tier down's savings: 55% instead of 60%, as in the example from Angel,  My calculator says, that price should be $20.25. Also lower than 21.72)
  • CES3DCES3D Posts: 262
    Angel_X said:
    Hi!
    The items under Doorbuster / Debut / Still New Releases already have a default 30% discount. The Punch Card discount replaces this default 30% discount—it doesn't stack on top of it. (If it were an additional discount, it would be explicitly labeled as an "Extra" discount.)
    Here is how the pricing breaks down for the $99.99 Angus 9 HD Character Bundle:
    1. Standard Page Price ($48.99): This item has a default 30% off. Because it's a Daz Original, members get an additional stacking discount (30% off for Daz+, or 35% off for Premier). Assuming you are a regular Daz+ member:
      $99.99 × 0.70 (Default 30% off) × 0.70 (Daz+ 30% off) = $48.99 (Store page price)
    2. Your Cart Price ($31.49): With 15 punches, your Punch Card discount for Doorbuster items increases to 55%. As mentioned, this 55% replaces the default 30% discount:
      $99.99 × 0.45 (Punch Card 55% off) × 0.70 (Daz+ 30% off) = $31.49
    So the math in your cart is actually correct! The Punch Card simply upgraded the base discount from 30% to 55%, rather than taking 55% off the already-discounted $48.99 page price.
    CES3D said:
    Angel_X said:
    Hi!
    Thanks for the explanation.
    It would have been much simpler if the price had been $69.99, with a 55% discount applied via the 15 Punches.
    I’m afraid I’ll have to hold off on purchasing the bundle, which I’m really sorry about.
    edited October 23
    Except if you go to the shop page for Angus 9 Character Bundle, it doesn't say 30% off. It says 55% off. Why is that?
    Post edited by jmucchiello on
    edited October 23
    That is because Angus 9 HD Character Bundle is a Daz Original, and you are likely logged in as a Premier member.
    For Daz Originals, the store page dynamically displays the price with your Daz+ or Premier membership discount already applied:
    • Default Doorbuster discount: 30% off
    • Premier member discount on Daz Originals: 35% off
    • Combined: 0.70 x 0.65 = 0.455, which translates to roughly 55% off on the store page.
    If you log out of your Daz account (or check in an incognito window), you’ll see the base 30% off that Base members see.
    If you are wondering why Daz chooses to bake the membership discount directly into the product page price rather than waiting to apply it in the cart—well, that's just the way Daz designed their store system!
    Post edited by CES3D on
  • MonkeMonke Posts: 72
    Getting "coupon code not valid" with 24HR-PICK and my only available option https://www.daz3d.com/asymmetric-strap-suit-for-genesis-8-and-81-females in the cart. I have 21 punches.
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,912
    edited October 23
    same here btw was wondering how come you have 21 punches when I'm 15-16 then relised you must be premier member bonus
    Post edited by ANGELREAPER1972 on
  • Cris PalominoCris Palomino Posts: 13,063
    I just tried it and it did work for me.
    It's working for me now too. Nothing changed except that I bought something else in a separate cart before it.
  • genarisgenaris Posts: 382
    Hi!  I have 16 PUNCHES;   the  DOORBUSTERS says 2+ products gets EXTRA 20%   so when i put 1 doorbuster [ https://www.daz3d.com/m3d-dforce-classic-rebel-outfit-for-genesis-9 ]  into cart, it goes in at 60% -correct for 16 punches on a doorbuster. But when I add another [ https://www.daz3d.com/jmr-dforce-vincent-outfit-for-genesis-9-and-8-male ] it also goes in at just 60%,  when both should go up to another 20 extra discounted.  I even tried adding a 3rd Doorbuster [ https://www.daz3d.com/bw-midnight-lace-foot-wraps-for-genesis-9-8-and-81-female ]  but it still kept all three items at only 60% off.
    Find YOUR discount above
    Plus an Extra 20 off* 2+
    The extra 20% isn't working.
    738 x 644 - 95K
    The extra 20% issue has been reported.
    The extra discount was text that should not have been there and has been corrected.
    I find this "fix" (which isn't a one time event seen only today) the most egregious of all the Daz shop's foibles. Lost sale. Sorry to the PAs affected.
  • LindaBLindaB Posts: 196
    Gift cards are being offered at 10% off or 20% off with a new release in your cart and the code: COUNTDOWN-8. I had a new release in my cart, yet the gift card was only discounted 10%, What's going on?
    I see where the confusion came from, but you are misreading the offer.
    This promotion works via the coupon code COUNTDOWN-8, which gives an exclusive "either / or" choice between two completely different perks:
    • Option A: 10% off a Gift Card
    • Option B: An extra 20% off one New Release item
    Here is how the system logic and coupon restrictions work:
    1. The "Extra 20% off" applies only to the New Release, never to the Gift Card. There is no 20% discount on gift cards in this promo. The discount on a gift card is strictly capped at 10%, even if you have other items in your cart.
    2. The coupon can only be used once per account. Because this code is single-use, choosing one perk means giving up the other. If you use it to get the extra 20% off a New Release, you can no longer get the 10% discount on a Gift Card, and vice versa.
    3. You cannot have a Gift Card in your cart if you want Option B. The system will prioritize the Gift Card discount (Option A) whenever a Gift Card is present. To claim the extra 20% off your New Release, you must remove the Gift Card from your cart completely before checking out with the code.
    Decide which discount gives you more value before placing your order, as the coupon cannot be reused!
    I see now, I should have read it more carefully. Thanks for clearing up the confusion.
  • rokkrrokkr Posts: 407
    "Dreamy Discounts
    Get an extra 20% off Featured Artist Stores and Gift Cards
    with any item over $1 by Zeddicuss, Lyoness, or Dreamlight
    Coupon code usable once per customer."
    Which coupon!?
    I believe that is supposed to mean Just One Gift Card. But I just tried to buy another gift card and it got the discount so, I'm curious too. What coupon? (Off to delete the second card...)
  • joannajoanna Posts: 2,854
    rokkr said:
    "Dreamy Discounts
    Which coupon!?
    I'm guessing this refers to the other offer which allows you to get Zeddicus, Lyoness, or Dreamlight item for $1.99, so close to the threshold of this offer.
  • Just wondering if Atticus for Angus 9 has been added for download via the normal Premier method as yet. Not showing up under install. This is the first Premier bonus figure I have had issues with. I know they can sometimes take a day or 2 but I think that ship has sailed.
  • nemesis10nemesis10 Posts: 4,058
    My own experience is that they show up within a week or so. The shortest time was next day and the longest took a week and a half. My expectation is by Monday or Tuesday.
    I would not count weekends in the "a day or 2" calculation.
  • Richard HaseltineRichard Haseltine Posts: 112,099
    joanna said:
    rokkr said:
    "Dreamy Discounts
    Which coupon!?
    Yes, I tested with a Gift Card and it got the discount with the qualifying item in the cart with no need for a coupon code.
  • TheLionTheLion Posts: 51
    It's not exactly clear whether "Prop Painter" is only compatible with Daz3D v6 or if it also works with v4.24. Going to assume it only works for v6, but it's not indicated anywhere.
  • StonemasonStonemason Posts: 1,316
    It's for ds4 and ds6, I have a note in with Daz to add that to the product page
