Genesis 9 right eye issue
I've tested all the Genesis 9 figures, and they all seem to have the same issue: when looking up, the right lower eyelid gets pulled down in a very unnatural way. Is this a problem with my DAZ Studio version, or is this a known/common issue with Genesis 9?
  • Richard HaseltineRichard Haseltine Posts: 111,972
    Probably neither - most likely it is a corrective morph belonging to another characater or shape triggering when it shouldn't. If you find the minimum figure chnage needed to trigger the error and turn on Preferences>Show Hidden properties in the Parameters pane option menu (the lined button in the top corner) then you can go through the hidden morphs zeroing them until the issue goes away, then click the gear icon on that slider>Parameter settings to see where the morph comes from.
