DAZ Crashes Without Rendering
Greetings!
I am trying to render a sprite. I've had DAZ crash when I get to certain frames, and then I reload the scene and start rendering from that point, and there's no real problem.
This particular render crashes the moment it first starts trying to render. If I try to preview it by switching the viewport to Iray, it crashes. If I hit the render button, it crashes.
Is there a way to tell WHY the program is crashing? Obviously something about this particular scene is making it crash, but I have no idea what.
Thank you
Have you looked at the log file (Help>Troubleshooting>View Log File, look before the latest Daz Studio is starting line)? Do you get a crash report dialogue, or does the application just vanish?
I did not look at the log, because I didn't know about it, but since it's worked since then, that log seems to be gone. Is there a place where there are stored past logs?
I did get a pop-up window that it had encountered an error and needed to close. I don't remember if it asked me to send in a report, but it does close down entirely the moment that I click okay.
The strange things about it are that today, the scene renders fine, and when I first tried to do it, version 6 crashed repeatedly, but 4.24 rendered it correctly.
If it is the DS crash rported there should be an option to save the crash report - you could then attach that to a post.
The log gets reset after exceeding a certain size; there is no archive of past logs, unless you are using back-up software that is set to include the Appdata folder
What OS are you on?
There seems to be a bug in DS 6 on macOS tha causes Iray to crash, if the bug is in Iray or not I havent figured out but the crashes are in the Iray render threads, and happens with certain item.
