[Released] Hat Check for Genesis 8 [Commercial]
Quickly and easily create hair morphs to use your hair with different hats and caps, even sunglasses and hairbands!  Hat Check works by using a sphere, cylinder or cube to define an Effect Volume which you position over the hair.  Any hair vertices inside (or outside depending on the options) the Effect Volume will then be pulled close to the head of the figure.  Any hair vertex outside the Effect Volume, but within the feathering distance, will be pulled partially towards the head of the figure.
Hat Check creates 2 morphs for the hair based on the label of the "hat": one using the label name (e.g., "RS Fleur Hat") that controls all hair vertices inside the Effect Volume, and one using the label name plus "feather" (e.g., "RS Fleur Hat Feather") for all the vertices at the edge of the Effect Volume.
  • Quickly create hair morphs
  • Includes 2 scripts for creating hair morphs
    • Use Effect Volumes (Cube, Ellipsoid, or Cylinder) to specify the hair vertices to morph
    • Use Selected Vertices to specify the hair vertices to morph
  • Morphs can be saved separately or as part of the scene file
Morphs created by Hat Check are a Merchant Resource, which you can distribute with your Hair product.
  • CrescentCrescent Posts: 335
    Is it just G8 or does it work for G9 as well?
    • Hat Check for Genesis 8: (.DSE)
    • Scripts:
      • Hat Check for Genesis 9 Script
      • Hat Check Geometry for Genesis 8 Female Script
      • Hat Check Geometry for Genesis 8 Male Script
      • Hat Check Install Custom Actions Script
      • Detailed User Guide (.PDF)
  • LeanaLeana Posts: 13,609
    Description was most likely copied from the G9 version released some time ago: https://www.daz3d.com/hat-check-for-genesis-9
  • ElorElor Posts: 4,197
    The files list also has no mention of the Genesis 9 script:
    http://docs.daz3d.com/doku.php/public/read_me/index/105845/file_list
    • Scripts:
    It is a copy and paste error.  This is for g8 only.  I will let Daz know.
  • tsroemitsroemi Posts: 3,637
    I'm really happy this came out so fast after the G9 version, thanks! Landed in my library with the wishlist discount today. One of the BESTEST and most useful ideas of this year, the hat check yes
    You're welcome!  I am so glad you like it.
    FYI, a G3 version is coming too.  I don't plan to support anything earlier unless there was a lot of demand.
  • Should the scripts be compatible with Genesis 8.1, or is it an error that this generation is listed under Compatible Figures?
    I get the following error when using Genesis 8.1 figure:
  • When using Genesis 8.1 it doesn't work at all, it keeps saying that the hair must be a child of Genesis 8 Figure.
    What's the fix for it ???
    Thanks
  • ChoppskiChoppski Posts: 688
    I am having some issues. The x and z scaling is scaling both directions.
    Also, when i use the geometry tool as soon as I crtl select the hat the geometry stops showing and if I try to use the script it asks me to select vertices on the hair, which show up as checked if I unselect the hat.
    They are linked by default: there is a box to uncheck just below the X,Y and Z scaling sliders;
    Thanks
    I can confirm the issue and am working on it.
    There is a link checkbox.  Uncheck it.
    With the geometry tool, are you selecting VERTICES?  By default, DS selects polygons.
  • RiverSoft ArtRiverSoft Art Posts: 6,977
    edited February 2025
    The other thing that can happen is that you have both the hair and the hat selected and then you use the geometry tool.  You might be selecting the vertices of the hat instead of the hair.  Select ONLY the hair and then select vertices.
    Post edited by RiverSoft Art on
    Thanks
    Has this been fixed now?
  • kai.braaten said:
    Thanks
    Would love to know this too, was going to buy it when I read this, waiting for a message that it works for G8.1 female also, I don't use any other generation of models.
    It is:
    Resolved Issues
    * 2025-02-12:
    • Fixed Genesis 8.1 support
    • Added Genesis 8.1 Mask Objects
    • Updated data/RiverSoft Art/Common/RSHatCheckConstants file
    • Added Mouth Realism HD and Legacy Eyelashes names to the IGNORED_MORPHS variable
    https://docs.daz3d.com/public/read_me/index/105000_105999/105845/start
