On the subject of G9 Anatomy....
garrett_3d
Why are the G9 nipples pointed like a witch's hat? No matter what character I use or what slider I adjust, they always come out to a sharp peak.
Is this a known issue?
Genesis 9 navel and nipples are added through Lvl 3 HD Morphs: Genesis 9 load by default with a viewport SubD Level of 1 (in other, the viewport won't be able to show how navel and nipples were created) but G9 does render by default at a SubD level of 3, so you will see these morphs on a render (a real one: Iray preview is using the viewport SubD level value, not the render Sub level value).
You can of course increase the Viewport lelve, under Mesh Resolution in Parameters with the figure itself selected.
I *think* I understood that. However, even in a full render, they are still pointed. But for obvious reasons, I can't post the pics here.
I'll have a play with some settings and see what happens.
They arent the best, even the HD morphs that come with Essentials Expansion or Extras (cant remember) IMO which is why there are so many nipple products here & on other stores. Increasing the min render subdiv helps a lot, of course it makes renders take a lot longer
