VOOTW G9
garrett_3d
in The Commons
Purchased a few of VOOTW's characters recently as they were cheap. Every single one is missing nearly all the texture files.
Anyone else noticed this?
Will I need to submit a ticket for each item? I have about ten of them so it would be time consuming.
I don't know if this helps, but the most recent one I purchased, VOOTW Lrene, on 8/18/26 as a Quick Grab; nothing is missing; everything works.
Just looked though the zip file, all the textures are in the wrong folders, they're in "Content\People\Genesis 9\Characters\VOOTW\*character name*\Materials" instead of "Content\Runtime\Textures\*character name*.+
So I need to manually re-direct Daz to their location.....
That's strange. I pretty much use DIM for all my purchases here including my VOOTW characters.
You should open a ticket with Daz support to ask for a fix.
(Even the second path feels wrong, that folder with the character's maps should not be at the root of Runtime/Textures but at least in Runtime/Textures/VOOTW)
Never had an issue with them. Perhaps you could name one that goes awry, to check
So far, out of 18 VOOTW characters I have checked, only one is unaffected and that is Mandy HD.
Affected characters I've found up to now are: Aggie (and young), Cora (and young), Haru, Joni, Julie (and young), Laleh Young, Mandy Young, Mao (and young), Sarah, Yoko (and young), Yume (and young).
Despite having all the textures available, Daz is only loading the front and rear torso - these are the only files in the proper materials folder.
All installed using DIM.
I think, when I build my third PC for G9 stuff, I shall manually install everything so I can catagorise assets logically as I install them.
I think this is something DAZ should definitely know about. I doubt you would have to file a ticket for each individually.
The "problem" with several VOOTW characters is that some of these characters are add-ons and require the main character for textures. Laleh Young and Mandy Young both require their respective "base" characters (and it's stated on their respective pages as a requirement}. So, any of the Young characters more than likely do not contain all of the needed textures in their zips (check the Requirements section of their store pages).
All of the VOOTW characters I have do have their textures in RUNTIME/TEXTURES/*character name*. I have Julie and its add-ons, and checking DIM shows textures are in the expected places.
Tried three of your list, including one young version (which only changes the shape) and got no problems with loading the textures. Using 4.24.
Sorry, this seems to be an elusive problem.
I've tried the adult versions of the characters and got the same problem. Looked into the file paths and the textures hadn't installed for some reason. Uninstalled via DIM and did a manual install. All sorted now.
