Culprits or Fixes for Teeth Issues on G8.1F?
I've reset the figure of my G8.1F and tried again but for some reason the teeth reduce themselves, and I'm not using teeth morphs. I've attached what it looks like and what some of the other morphs I'm using are, like toon shapes burn face, and volume muscles. I've set them all the zero though and that does not fix it, so I'm not sure the problem even is a morph? Thoughts or fixes? Thank you.
Update: Fixing mouth realism helped but didn't really solve it, I looked into hidden parameters and don't see anything that could be suspect. I'd like to just make the teeth more normal looking
In short, yes, the issue comes from a combined auto-follow morph when you (or a content creator) customize or convert a character, especially with Mouth Realism set as 100%. They're sort of baked rather than hidden, so you have no way to find them from Parameters pane. Therefore better always zero Mouth Realism first of all when customizing especially converting characters ~~
If you get such an issue on G8 and want to fix it, the common ways can be:
1) Clear all morphs / deltas from the geometry of mouth (incl. teeth), re-rig it and update Full Head Morph or create as a fix morph
2) Or, zero Mouth Realism 1stly, then fix the teeth by using some products, e.g.
https://www.daz3d.com/easy-teeth-for-genesis-8-female-s-and-merchant-resource
https://www.daz3d.com/teeth-master-control-for-genesis-8-female
oof, right in the wallet. wishlisted for now thanks
