Uploading New Surfaces Without Using Geometry Editor?
Write Idea
Quick question: is there a way to upload new surfaces into DAZ without having to use the Geometry Editor tool?
I have a very complex model with hard to reach surfaces. And it's so much easier to use Blender to create surfaces.
I know there is a simple way to upload new UV Sets by doing EDIT>FIGURE>SURFACES>LOAD UV SET. Is there something simple/similar for surfaces?
Thanks in advance.
Import rather than Upload.
You could try Edit>Object or Figure>Update Base Geometry, I can't recall if that will work here or not.
There's no built-in function in DS to do what you want other than using a Daz Script.
You can just import the OBJ file of the model that was exported from Blender with newly-created Materials.
Or consider using this plugin : https://www.daz3d.com/blender-to-daz-studio-plugin
