What did I do wrong?
dennisgray41dennisgray41 Posts: 910
edited September 15 in The Commons
Just trying out some utilities and found this one for Dusty HD Cowgirl Outfit for Genesis 8 Female(s) Dusty HD Cowgirl Outfit for Genesis 8 Female(s) | Daz 3D
The utilty SEEMED straight forward enough "Dustry bolero hat clip plane for hair" So it should clip the hair to fit the hat right?  Figure 1 is no utility. Figure 2 is with the utility and select hair. Btw, the model is DD Rissa for gen 8 and the hair is Joy hair. Fig 3 is everything selected and fig 4 is with the hat selected. Somehow, I do not think this is how it is supposed to work.
Post edited by dennisgray41 on
  • TaozTaoz Posts: 10,351
    Select the hair and apply the Clip utility.  Works for me.
    edited September 15
    I didnt have Joy hair so I first tested with another one, but since Joy hair is in the Outlet and I had it wishlisted, I purchased it, and tested it to see if there were issues.  There is a little poke through with that hair, but it's fixable by adjusting the hat a bit.  See video:
    https://app.screencast.com/4P3UdWJ36KgUl
    I guess you can also use the Geometry Editor instead to remove the hair poking through.
    Post edited by Taoz on
    Much better. Thanks somuch for going the extra mile and buying the Joy hair. It worked just right then I tried Biscuits Noa Hair to give it a real test/
    480 x 561 - 215K
    480 x 561 - 334K
    480 x 561 - 337K
