How to establish the pixel size of a selected surface?
DoctorJellybean
[How to establish the pixel size of a selected surface?] An example, I want to use a floor standing mirror for a standing picture display.The mirror has it's own surface. Now I need the pixel dimensions of width and height of that surface to create the image to fit.
If you are using a custom image in the surfaces tab, you can scale it on the x and y axes to fit.
Not sure I understand.
As I see it, only the ration (between sides) is relevant.
You can calculate the pixels of the width and height of the selected Mirror surface by using a Daz Script, but it'll still depend on the UV layout of the Mirror surface if you want to place a picture on the surface, as barbult mentioned.
So you can simply hide the Mirror surface, then replace its space with a primitive plane, Scale it with X/Y Scales, then you'll get the dimension ratio. Then prepare the image by using the dimension ratio accordingly. Finally, place the image into the Base Color slot of the primitive plane and finetune the shader settings.
Or, align the image based on the UV template but some UV layout may require further adjustment of Tiling, so it might be a bit cumbersome ~~
Is this post render (you are wanting to place an aimge over the rendered reflections) or pre? For pre it is as others have said, you can use any image size you just need to make sure it occupies the right relative position of the map - DS 6 will let you select the surface then in UV View export the template without any other distractions.
