COME HERE do not work anymore in the new DAZ version (solved)
daybirddaybird Posts: 683
edited September 15 in Freebies
One of the most useful tools do not work anymore in the new DAZ Version.
Is there any chance we can get an update of this tool?
Post edited by daybird on
  • felisfelis Posts: 6,644
    mCasual was last active mid August. He might update them, but my guess would be a low probability.
    You can try sending him a PM.
  • New DS 4  version or do you mean DS 6? I assume the latter.
  • StargazeyStargazey Posts: 286
    edited September 14
    I'm using the latest version of  DS 4 and it works in that.
    mCasual has done several versions of the mcj Come Here script, so it might be worth trying the others in DS 6.
    Post edited by Stargazey on
  • jmucchiellojmucchiello Posts: 2,694
    I just downloaded the 2022 Come Here script and it seems to work fine on DS6 for me. (And now I'm creating a custom action for it.)
  • daybirddaybird Posts: 683
    That's what happen when I try to use it under DAZ 6
    1079 x 296 - 78K
    edited September 14
    Are you running the 2020 or the 2022 version? I downloaded the 2022 version only.
    743 x 134 - 9K
    Post edited by jmucchiello on
  • CES3DCES3D Posts: 262
    The mcjComeHere script mentioned by daybird and the mcjComethHere script mentioned by jmucchiello are actually two different tools.
    The dialog for mcjComethHere has a very simple interface. It only gives you two choices: move the object in front of the camera by changing all of its X/Y/Z coordinates, or move it only along the X and Z axes without changing the Y coordinate. The object's final position is always fixed at a distance of 4 meters from the camera. mcjComethHere 2022 worked without any issues in my DS6 environment.
    On the other hand, mcjComeHere brings up a dialog with detailed settings. You can configure options such as the exact distance between the camera and the object, and you can also lock specific axes for the movement. mcjComeHere 2023 also worked perfectly fine in my DS6 environment.
    The icon daybird attached is from the initial 2020 version of mcjComeHere. I highly recommend downloading the newer mcjComeHere 2023 version first and giving it a try.
    1948 x 889 - 355K
    1948 x 889 - 378K
    edited September 15
    I didn't know there is a newer version. Big thx, I will try to find and download it.
    Well, I'd never tried either of these scripts before this thread started. Now I have to go look at the other script.
    @daybird
    I hope it works for you!
    @jmucchiello
    Same here, lol! I had never tried them before this thread either. We should thank daybird for giving us the chance to discover these handy tools.
    Thx a lot, the newer version works in DAZ 6. :)
    The latest mcjComeHere is 2023.https:https://sites.google.com/site/mcasualsdazscripts3/mcjcome
  • A little heads up. You can copy some dsa scripts in a regular Ai prompt and tell it to write the code to work with Daz Studio 6. This is just for compartibility not to resell.
