Free Pack — 4 HQ Architectural Shaders + Utility Presets
I'm giving away a small shader pack that I've made to get my hands into the creative side of the Daz ecosystem and become a vendor. I've been using Daz professionally for over 5 years now, rendering thousands of images and hundreds of animations, so I've designed these shaders with the goal to match the quality of the marketplace. This pack contains a diverse selection of architectural materials, all created in 4K to maintain a high level of surface detail.
Along with the shaders, I've included 10 different types of utility presets that I personally use all the time when working: Bump, Normal, Diffuse Colours, Translucency, Metallic Flakes, Sheen, Top Coat, Glossy, Tiling and Displacement.
Just simply click and apply what you want instead of wasting time fidgeting with the sliders and settings. And rather than vague terms like Low, Mid, High, the presets use more tangible names. For example, Glossy presets have names like: Eggshell, Plastic Bag and Wetness, so you have a better idea of what you're actually applying. Do bear in mind that actual results may vary based on your other settings, namely the bump and normal strengths.
Please let me know whether you like these or not, and any other suggestions you might have so I can improve future releases. I plan on releasing a few more of these small freebie packs so if you have any specific types of shaders in mind, like scratch, wounds, liquid/slime, specialized clothing (brocade, denim), emissives, etc. Please do suggest those too!
Thank you, and I hope you enjoy them!
File Size too big to attach on the forum: https://pixeldrain.com/u/5tLkkN94 (355 MB)
COMPATIBLE WITH DAZ INSTALL MANAGER (DIM)
