PAMAWO Military Nurse Outfit 1 - How to close the pockets?
Hi guys!
When I load the shirt for PAMAWO Military Nurse Outfit 1, its pockets are slightly open, sticking upwards, and look unkempt (like in the fourth promo image).  In most of the other promo images, the pockets are closed and lie flatter.  Unfortunately, I don't see any parameter dials I can use to adjust them, and running the dForce simulation doesn't seem to flatten them out either.  Besides using mesh-grabber, does anybody have any suggestions as to how I might tweak them?
Thanks for your help!
  • crosswindcrosswind Posts: 10,281
    edited September 9
    https://www.daz3d.com/dforce-military-nurse-outfit-1-for-genesis-9-8-81-female
    The issue mostly comes from poorly-set material zones as well as the settings on dynamic surfaces. I roughly tweaked the settings and added a dForce modifier weight node to G9 version so as to avoid the collar from collapsing and make the pockets close...
    You can load the attached Wearable Preset to a G9 and give it more finetune. Copy the settings on dynamic surfaces as well as the weight map to G8 version if needed.
    1919 x 1293 - 799K
    duf
    duf
    MN1 Shirt for G9.duf
    490K
    Post edited by crosswind on
  • foxstarfoxstar Posts: 25
    Thanks Crosswind!  I'll definitely give this a try!
