[Released] RSSY Clothing Converter from Genesis 9 to Genesis 8 [Commercial]
2»
  • The RSSY Clothing Converter G9 to G8F script fails immediately on launch, before any dialog appears.
    Log: Script Error: Line 89 — TypeError: Result of expression 'pDirectory' [null] is not an object.
    Setup: Daz Studio 4.24, Windows. Scene contains only a default Genesis 8 Basic Female, at origin, default pose, selected.
    Content directories: C:/Users/ariel/Documents/DAZ 3D/Studio/My Library (first) and C:/Users/Public/Documents/My DAZ 3D Library. Both writable, both with a Runtime/Support folder. I recently moved all libraries out of OneDrive. Conformers are present in data/sickleyield2023/rssyg9ftog8fconverter/conformers. Reinstalled the product, same error.
    The G8M version fails the same way, and the Install Custom Actions script fails at line 37 with the same error.
  • Richard HaseltineRichard Haseltine Posts: 111,887
    edited August 31
    How did you instal? What is the full path to the script, starting from the drive letter?
  • arielgagnonarielgagnon Posts: 6
    edited August 31
    Installed via DIM. Full path: C:\Users\Public\Documents\My DAZ 3D Library\Scripts\RiverSoft Art\Clothing Converter\RSSY Clothing Converter G9 to G8F.dse
    I have since done a completely clean reinstall: uninstalled in DIM, manually deleted every remaining file (scripts, RSG9G8CCConstants.dsa, RSG9ToG8ClothingConversionFunctions.dse, the data\sickleyield2023 conformers, the XML and the Runtime/Support metadata), then reinstalled. All 336 conformers and both Common files are present. Daz Studio was restarted. Same error, unchanged.
    My content directories are C:\Users\ariel\Documents\DAZ 3D\Studio\My Library (first) and C:\Users\Public\Documents\My DAZ 3D Library (second). Both writable, both with a Runtime\Support folder. Nothing is on OneDrive or a network drive.
