The morph disappears after reloading the scene
The problem is this:
I'm using the "Body Tone" morph to make the model more defined. I also remove the limit and set it to 200% for a stronger effect.
Then, if I reload the scene, the morph disappears, and this happens.
If I try to create a completely new scene, the morph is still there, but if I apply it and reload the scene, it disappears again.
How can I fix this? So that the morph doesn't disappear?
I'm using - "Body Mixer Bundle for Genesis 3 and 8 Male and Female"
  • Richard HaseltineRichard Haseltine Posts: 111,996
    Please put the Viewport into Smooth Sahded draw style, or give the character some clothes.
    https://www.daz3d.com/body-mixer-for-genesis-3-and-8-female is a set of pose controls, so removing the limits of those won't affect any limits on the base morphs that are being triggered. That doesn't explain why saving and reloading changes the result, but it is a factor to be aware of.
    As for the error, how did you install the products (the mixer and the base body morphs)?
