After product update Ultimate Zero by Riversoft now works in DAZ 6 but no longer works in DAZ 4.24
Hi, I hope you can help me. I use 'Ultimate Zero' by Riversoft a lot and it has stopped working in DAZ 4.24. I recently installed an update for the product and it now works in DAZ 6 but no longer works in DAZ 4.24. Log file details are shown below.
I share the same database for both DAZ 4.24 and DAZ 6 because I have a 5090 video card and frankly the viewport performance in DAZ 6 is simply not good enough. I do my work in 4.24 and then render in 6 and I'm sure I'm not the only one doing this. Since 'Ultimate Zero' no longer works in 4.24 I am really frustrated. How can I revert to the old version of 'Ultimate Zero' from before the update?
Thanks for your help, John
Here is what happens in 4.24.
In some cases when I run a script a message pops up saying "... file could not be loaded." Here is an example of what the log says in this case:
2026-08-05 10:06:15.024 [INFO] :: Loading script: D:/DAZ Content/My DAZ 3D Library/Scripts/RiverSoft Art/Ultimate Zero/Ultimate Zero Selected.dse
2026-08-05 10:06:15.024 [WARNING] :: Failed to load script: D:/DAZ Content/My DAZ 3D Library/Scripts/RiverSoft Art/Ultimate Zero/Ultimate Zero Selected.dse
For some of the scripts no message appears but nothing happens. Here is an example of what the log says in this case:
2026-08-05 10:02:18.494 [INFO] :: Loading script: D:/DAZ Content/My DAZ 3D Library/Scripts/RiverSoft Art/Ultimate Zero/Ultimate Zero Expression.dse
2026-08-05 10:02:18.496 [DEBUG] :: FOUND: D:/DAZ Content/My DAZ 3D Library/data/RiverSoft Art/2025Common/RSConstants.dsa
2026-08-05 10:02:18.496 [DEBUG] :: D:/DAZ Content/My DAZ 3D Library/data/RiverSoft Art/2025Common/RSConstants.dsa
2026-08-05 10:02:18.496 [DEBUG] :: Execute Script: D:/DAZ Content/My DAZ 3D Library/Scripts/RiverSoft Art/Ultimate Zero/Ultimate Zero Selected.dse <Settings> <Setting Type="String" Key="Title">Ultimate Zero Expression</Setting> <Setting Type="Bool" Key="Recursive">yes</Setting> <Setting Type="String" Key="Body Part">Expression</Setting></Settings>
2026-08-05 10:03:21.633 [INFO] :: Script executed successfully: D:/DAZ Content/My DAZ 3D Library/Scripts/RiverSoft Art/Ultimate Zero/Ultimate Zero Expression.dse
Hi, Another question about 'Ultimate Zero'. When I search for it on the DAZ web site it is very hard to find. Searching on "ultimate zero" from the "Shop" page finds 59 products but does not include the product who's name is an exact match. If I do a search for 'Riversoft' on the DAZ web site it displays "193 of 258 items". I un-checked "hide items I own" and all other filters but it still hides 65 items and I guess 'Ultimate Zero' is one of them because it does not show up. The only way I can find the product is to go to my account and search my product library for it. What is going on with this product?
This https://www.daz3d.com/ultimate-zero
Short version, you can't, unless you had a local backup.
You might be able to submit a support ticket and they MAY send you a link for the older version, but it's unlikely.
Please use the PA's support thread, if the topic hasn't already been covered https://www.daz3d.com/forums/discussion/430871/released-ultimate-zero-commercial#latest
