Changing the grid units from inches to cms
Hello friends a dumb question here, I want to work in cms or meters in vertex room, and I want to set up my grid based on those units metrical system, but I can't find how to do it, and I can't find neither a relate topic in serach function, anyone can help me out?
Best regards
Otto
  • pimpypimpy Posts: 274
    edited December 2015
    Best regards
    Otto
    Hi Otto
    you must change the default settings in "preferences" from inch to metric smiley
    960 x 600 - 205K
    Post edited by pimpy on
    OR, for a temporary change, select the SCENE in your Instances thab, then go to Interfaces, & Displayed Units in the properties window. This will set the units for the current session.
    373 x 896 - 211K
  • otodomusotodomus Posts: 332
    Thank you Tango Alpha and pimpy for your quick responses, yes
    It was easy, and believe me, I have years working with Carrara and its the first time I needed to change the units setup and I had no idea how to do it cool
  • RoygeeRoygee Posts: 2,247
    Don't put too much trust in changing the preferences to metric, unless theyv'e been corrected in 8.5.  Two instances that come to mind are replicating with offset in the VM and the motion path - both work in inches, regardles of what units you have set :)
    ...but if you type in a value followed by "cm" you'll get cm, "mi" for miles, "km"... etc., and it will automatically convert your response to the inch equivalent.
    Yes, that is a quick way of doing it without having to change preferences...but it won't work in the two cases i mentioned (and a few more I don't recall offhand), because there is no input option:)
