Transferring Morphs from V3 and V4 to Genesis
AlricAlric Posts: 224
I have some utilities to transfer character morphs from various versions of Genesis to other versions (G3 to G8 etc). Is there any way to get V3 and V4 morphs into Genesis (preferably g8 or g9 but g3 would work)? I'm not wirried about the textures just the morphs.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,625
    GenX with the addons will get you to 3
  • AlricAlric Posts: 224
    Oooo, I already have those!
    Thanks
  • richardandtracyrichardandtracy Posts: 8,119
    I'd love to hear how it goes. I have GenX and the addon bits for V3 & G3, and I have to confess the best I'd say about the conversion is that it's 'Vaguely Reminiscent' of the original and by 'vaguely' I mean 'Hardly at all.'. However, it could just be me being incompetent - which is highly likely.
    Regards,
    Richard
  • Singular3DSingular3D Posts: 674
    I'm interested in this as well. Have a lot of V4 and M4 morphs and would love to use them with G8/G8.1
    I will try to get to it today.
    So far no luck. The UI is missing a button so I don't know if something is missing or if it no longer works. I will play with it some more and see if I can get it working.
  • HavosHavos Posts: 5,704
    edited July 30
    It can be done, so keep trying. This is V3 shape on G8F. I transferred it a long time ago, but I used GenX2 to get to G3F then XTransfer to get to G8F.
    Remember you need to have V3 installed in your runtime in order for the transfer to work.
    2048 x 2048 - 149K
    Post edited by Havos on
    edited July 30
    Nice, maybe you have some insight. When I try to transfer the morph I don't get the target selection button. Do you remember if you encountered something like this?
    I attached a screen shot of what I see and a picture from the user manual showing what it should look like. Note the button labeled "Victoria 4" at the bottom is for the original shape and is correct. There should be another button under it for the target figure.
    *** Edit ****
    I noticed the panle says "Genx" and the about also says Gen X version 1.2 But DIM says that I have Gen X2 installed. Maybe my serial number is wrong and Studio thinks I only have Genx. I will investigate.
    571 x 1034 - 49K
    996 x 794 - 156K
    Post edited by Alric on
    There are a lot of Gen X2 packages to be installed. Check you have all of them installed. I think they need to be installed in the same runtime as the Genesis 1-3 essential packages Maybe V3/V4 should also be in the same runtime. Make sure GenX2 addon for Genesis 2 and GenX2 addon for Genesis 3 are installed.
    Are you saying the Target drop down menu is only showing Genesis, and the Genesis 2 and 3?
    edited July 30
    I got it working!
    It seems that DIM installed both GenX and GenX2 at the same time. It's not supposed to do that. I unistalled GenX and then the target button finally showed up. I was able to transfer a morph from V4 to Genesis 3.
    The attached screen shot shows how it looks now.
    774 x 967 - 51K
    Great, well done
    Now I just need to install V3 and see about transfering some old Aery_Soul characters to G3.
