Is this PA Product Compatible with DS4 and DS6 ?
hjake
Is ND Cloth Simulation Toolkit ( https://www.daz3d.com/nd-cloth-simulation-toolkit ) compatible with DS4 and/or DS6?
Post edited by hjake on
It's presets, they are not version dependent (as long as you have a version with dForce, of course). Scripts (possibly) and plug-ins (definitely) are the ones with version requirements, check the list of What's Included to see if a product has either of those.
Hi Richard,
Daz Studio Iray Shader Presets (.DUF)
ND dForce Scripts User Guide EN.pdf
These are the "helper scripts" in the file list
Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND !dForce Diagnostic.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND !dForce Diagnostic.tip.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND !Emergency Rescue.dsa
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND !Emergency Rescue.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND !Emergency Rescue.tip.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND !Preserve Shape.dsa
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND !Preserve Shape.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND !Preserve Shape.tip.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND !Reset dForce.dsa
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND !Reset dForce.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND !Reset dForce.tip.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND !Stabilize Fabric.dsa
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND !Stabilize Fabric.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND !Stabilize Fabric.tip.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Leather Rescue Strong.dsa
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Leather Rescue Strong.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Leather Rescue Strong.tip.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Less Drape.dsa
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Less Drape.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Less Drape.tip.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Less Flow.dsa
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Less Flow.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Less Flow.tip.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Less Structure.dsa
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Less Structure.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Less Structure.tip.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Less Volume.dsa
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Less Volume.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Less Volume.tip.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Less Weight.dsa
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Less Weight.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Less Weight.tip.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Less Wrinkles.dsa
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Less Wrinkles.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Less Wrinkles.tip.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Drape.dsa
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Drape.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Drape.tip.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Flow.dsa
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Flow.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Flow.tip.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Structure.dsa
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Structure.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Structure.tip.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Volume.dsa
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Volume.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Volume.tip.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Weight.dsa
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Weight.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Weight.tip.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Wrinkles Extreme.dsa
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Wrinkles Extreme.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Wrinkles Extreme.tip.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Wrinkles.dsa
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Wrinkles.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND More Wrinkles.tip.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Smoother Fabric.dsa
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Smoother Fabric.png
/Shader Presets/Nathy-Design/ND dForce Simulation Toolkit/03 dForce Helper Scripts/ND Smoother Fabric.tip.png
Would these scripts require the SDK to write or are they simpler than that?
SAFE Script Workflow
The helper scripts are designed as safer adjustment tools.
They do not modify:
These advanced settings can cause unstable simulations on some meshes or fabric setups, so the ND helper scripts focus on more practical fabric adjustments.
Yes, the scripts work in both DS 4.2x and DS 6 ~
Merci Beaucoup.
