How do I fix this??
My Gen 9 characters are doing this and I'm not sure what the fix is. Any suggestions? Is it a plugin that is causing it, and if so how do I find the culprit?
  • NewGuyNewGuy Posts: 334
    edited July 27
    It looks like some type of corrective morph is firing before it should.
    Select your figure, go to the parameters tab and from the hamburger menu in the corner, under preferences, turn on show hidden properties.  Filter by currently used.  Now you will have to go through the active properties and zero them to see which one is causing the problem.  I'd suggest start with any that have "cbs_" as a starting label.
    Post edited by NewGuy on
  • DesignemDesignem Posts: 71
    Thanks for teh help, Yes, I found that there are two different characters that are mixed in. How do I get rid of that?
    I've had issues like that before when I added a corrupted asset like a character, but I couldn't tell you which one I've loaded that would cause the issue. I have multiple characters on my machine.
    419 x 571 - 90K
