Please help me find a Dforce skirt with a ruffle that starts out as a circle around waist
2»
  • crosswindcrosswind Posts: 10,329
    Jan_Scrapper said:
    Getting an error message with Optimized Tris to Quads Converter
    I don't have such an error when manipulating the skirt you gave us with this free add-on ~~
    However unfortunately it's just a "converter" to convert tris to quads in a simple way....rather than a remesher for retopo. In the case we were talking about, you need the latter ....
    2560 x 1392 - 1M
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,660
    Zremeshing didn't do it any favours, I did try it
    a modeled skirt would work better, I started trying to do one but have too much going on, I too find it hard to create ruffles that don't straighten out with Dforce, for me it requires welding bits together like adding an extra point on each fold and linking it behind like a shirring elastic thread, that takes a lot of time and technically creates ngons
  • felisfelis Posts: 6,553
    You could possibly make it work using dForce add-ons.
  • Jan_ScrapperJan_Scrapper Posts: 798
    crosswind said:
    Yes, it should bring you better draping in most cases from simulation perspective... as long as you give it an optimal settings (on dynamic surfaces, with a dForce Weight Node... etc.), but it may also bring issues when rigging the skirt to the figure because the skirt is much more closer to the arms, Transfer Utility may bring unexpected weights to the edge of the skirt, then you have to further tweak the weights... otherwise when you bend figure's Arms, the skirt will follow. That's a common issue on quite a few products.
    As per my experience, in some specific cases, initial shape is a critical successful factor. You may see the screenshot 1 down below, the default shape of the dress can never drape well on the desk. I gave it a better initial shape by using Blender in screenshot 2, it draped pretty well and naturally as expected, in ss3.
    I did it here in my work:
    This is amazing work!!   Your talent is just amazing.  To be able to change a product to do what you want is fantastic!!  Just Beautiful!  Thank you for doing this experiment.
    I didn't see these last three posts until late last night.
    When I posted this, I was replying to a post on page 1.
    Thank you all for doing so much to try to get this skirt to work.
    If the ruffles won't stay ruffled (LOL) after Dforce animation, that is a problem.  I can have Meshy AI make a skirt after my character is posed.
