The Mindful Garden - Strand-based pubic hair for G8F
SquishySquishy Posts: 727
edited April 2025 in Freebies
"When the world wearies and society fails to satisfy, there is always the garden." - Minnie Aumonier
A collection of 10 strand-based pubic hairs fitted to DAZ Genesis 8/8.1 Female, with an assortment of 15 material setups in a good variety of colors.
These hairs are grown from a "flower box", a hidden set of polygons that is rigged to follow the main character figure. This was necessary to allow the hairs to be independent of a specific G8F/G8.1F version, as they are not compatible without this workaround. See readme for more details!
Sample previews can be seen at the download site (login required).
Since this type of item seems to be doing super well in the store, and since I got forum moderation's blessing to post this type of content as long as it's sanitized and gated behind a login and content filtering options, I decided to offer it here. Enjoy :)
Download: RenderHub (login required)
Post edited by Squishy on
  • tam_c3df5332fctam_c3df5332fc Posts: 147
    Hi @Squishy
    Thank you for this product and I usually have to do a little work to make it fit to my character
    First, I receive the following notification - see attached screenshot - Unable to 'Fit To' the target node...
    I have tried to select the Genesis 8 Female before double clicking on the desired strand based hair
    I have tried to select the Hip. I have tried to select the Pelvis. I have tried to select the XY genetals, but no matter what, I still receive this notification
    I downloaded this long ago and I no longer have the read me file.
    Can you please make some type of documentation available so that I can know what I am supposed to select before trying to apply the strand based hair?
    Thanks in advance - and I will probably send you the same message on renderosity
    BTW, the link to renderhub above is no longer working
    996 x 220 - 18K
  • SquishySquishy Posts: 727
    This is still available on Renderosity's free stuff listings:
    https://www.renderosity.com/freestuff/items/87968/the-mindful-garden-strand-based-pubic-hairs-for-genesis-881-female
    re: the problem you're having, the hair object is not intended to be conformed to the character itself, it's looking for the "Flowerbox" to be its parent.
    - Select the G8 character
    - Load the Flowerbox
    - Select the Flowerbox in the hierarchy manager
    - Load the desired hair item
  • StratDragonStratDragon Posts: 3,290
    edited July 18
    both links are barren.
    spoke too soon, the render hub is gone, the rendo hub needed me to login.
    Post edited by StratDragon on
  • richardandtracyrichardandtracy Posts: 8,124
    I think you already have to be logged into Renderosity and already have the filter set to adult. The link works for me. Regards, Richard.
