how do you get the background to show in Reality 4?
Simple Q really: I have only been using Reality 4 for about 2 days and whenever I render a scene with it in Daz the background is always black no matter what background I have there. I assume this is some sort of default thing as I have not played around with many settings. Is there simple way to remove the blackness so it can show whatever background you have loaded up? thankyou.
  • FSMCDesignsFSMCDesigns Posts: 12,855
    It's an unbiased renderer so I doubt it employs any of the biased techniques DS uses like backgrounds in the scene. I think the only option is to load a plane and apply the backgroud image to it or use an IBL or HDRI file
  • ToobisToobis Posts: 993
    K gottit thanks.
    Luxrender, by default will render a hdr used for lighting as a 'backdrop'.  It can also render an environment map as one, too...so I think Reality has the 'premultiply alpha' turned ON...which means it won't do that.
  • nDelphinDelphi Posts: 1,972
    View this on SmartIBLs:
