Adding to Cart…
It’s a year later and I still can’t get the script to work. This time trying the G8F version to mirror https://www.daz3d.com/dforce-roma-dress-for-genesis-8-females. I’m following the steps in the PDF manual precisely.
1. Load G8F base figure, and nothing else.
2. Select figure.
3. Launch script and configure.
4. Click Run. In the viewport, I see the script load the dress onto the figure. Then I see it flip (mirror). Then it disappears and the script apparently stops running. The expected “Update Base Geometry” dialog does not appear.
The script does create !MIRRORED ITEM.obj in the working directory but does not invoke the import step. If I try to import !MIRRORED ITEM.obj in the normal way, the program freezes — it doesn’t quit, but the import dialog is nonresponsive.
DAZ 4.24.0.4, Windows 11
Update: By poking around in the crash logs, I was able to discover that there is some kind of conflict or something between Mirror Geometry and Typi3D. I uninstalled Typi3D and the script ran as expected!
Well, fantastic! I am so glad you got it to work.
I bought this product today, could not get it to work no matter what I did, so have deleted it and requested a refund.
Ok. If you had worked with us, perhaps we could have got it working by showing us the log, your configuration, etc. A lot of times, it turns out to be something simple like you installed via Daz Connect instead of DIM.
