Nose morphs under ear shapes ?
I was making a custom character face, and I found this.  I use DIM for all DAZ3D content, so I'm sure this item is installing as it was meant to, but I cannot identify which product the nose morphs are from.  They have been installed into the ear section of Shaping.  So I'm just point it out in case anyone searches for the same set of nose morphs and can't find them under the Nose section. (A search in the Shaping blank may help, though !)
  • jmucchiellojmucchiello Posts: 2,749
    Click on the Gear on one of the parameters and select "Parameter Settings" from the little. This should give you a clue. (I don't have any nose parameters in my ears. A sentence I've type a million times before. I swear.)
    711 x 527 - 41K
    Thanks ! It appears to be part of G9 Fantasy Morphs.  Anyway, anyone looking for those using the Shaping tab will find them in the Ear section.  Just a heads up. Or use the search blank (that part of the listing that says " 'Enter an expression to filter by'... "
