Antique cast irons available?
DoctorJellybeanDoctorJellybean Posts: 10,177
edited June 26 in Freebies
Any antique cast irons anywhere?
Post edited by DoctorJellybean on
  • richardandtracyrichardandtracy Posts: 8,167
    edited June 26
    An .obj model is attached. No UV mapping. 3 material zones, Grip, Handles & Base Plate.
    Regards
    Richard
    763 x 480 - 32K
    zip
    zip
    Iron.zip
    14K
    Post edited by richardandtracy on
  • DoctorJellybeanDoctorJellybean Posts: 10,177
    Regards
    Richard
    Thank you!
    Sorry that I've not had a chance to turn it into a proper prop, but it's a start. Regards, Richard
  • emanuela1emanuela1 Posts: 1,238
    Very nice and useful object, thank you!
  • cosmosmcosmosm Posts: 107
    That is very cool.
  • UnseenUnseen Posts: 826
    edited June 30
    Thank you! Gives an excellent result (UVmapped and applied some shaders).
    483 x 657 - 471K
    Post edited by Unseen on
    That's great. Love it. Regards, Richard
    edited June 30
    Glad you like it. Do you want the UVmapped mesh? I can upliad it here (a scene subset for example or the obj file)?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,684
    edited June 30
    I have one in my shed minus it's wooden handle
    I also have the sort you fill with coals
    both pretty rusty and I am not going to look for them in that redback spider infested shed
    Upload however you want, very generous of you. Regards, Richard
    ha, we cannot upload real stuff yet, when we can, it will probably turn inside out like in Galaxy Quest cheeky
    That looks great! How did you set it up?
    I'll create my scene once I'm done with a series of renders.
    edited June 30
    You are welcome, Richard. But you are the generous person because you modelled the iron and shared it with us.
    The iron is UVmapped and has three material zones (handle, handle support and iron). i have included the three templates (2048x2048) in the arhive but applying materias is okay (as on the render above). The archive also contains the obj and mtl files as well as a Daz studio scene subset (no textures or materials because the ones used for the render don't belong to me). :)
    zip
    zip
    Old_Cast_Iron.zip
    168K
    edited June 30
    I just UVmapped it in my usual UVmapping program (Ultimate unwrap 3D Pro version 4). I also use blender with different and very useful free add-ons. but not this time.
    It was interesting to play with this model. :)
    Many thanks for your upload!
    You are welcome, DoctorJellybean. :)
  • ElorElor Posts: 4,188
    I repackaged your work, added default material using shaders included with Daz Studio, then added metadata.
    If it's okay with both of you, I can share the result (and then, to go full circle, someone who has a tool to create DIM compatible archive can take the whole work to create the DIM package laugh, I need to find some time to improve my own).
    I can create the DIM package.
    edited July 2
    For me, it's absolutely okay if you repackage the uvmapped prop but it belongs to richardandtracy. It is perfect if it can help the people who need such a prop. :)
    edited July 3
    I think he'll be quite happy with that, and I will create the DIM installer.
    https://www.daz3d.com/forums/discussion/comment/9578391/#Comment_9578391
    edited July 3
    Sorry, I'm still recovering from the recent heatwave and forgot to click on 'Post Comment' blush
    Perfect smiley Hopefully I didn't made any mistake while making and saving the metadata.
    Unseen said:
    For me, it's absolutely okay if you repackage the uvmapped prop. I just wanted to see if I could get decent UV coordinates with this item. I think it is perfect if it can help people who need such a prop. :)
    I'll assume that richardandtracy is still okay.
    I called the product R&T Unseen Old Cast Iron to have both of your names in it (I'm using R&T as a shorthand for the metadata for other freebies by richardandtracy) and you're both named as authors for Smart Content.
    There is one file to load the prop, one to load the material in case someone wants to tweak the materials by themself and get easily back the default mat.
    It's organised as such:
    • Props > ChestnutP & Unseen > Old Cast Iron
    • Props > ChestnutP & Unseen > Old Cast Iron > Materials
    In Smart Content, there should now be icons in the following categories:
    • Props::Tools
    • Materials::Iray::Props
    The icon (a 380x494 jpg file):
    Hopefully, the Filter by content checkbox will show the material if the iron is selected.
    If someone doesn't want metadata and prefers to organize their content as they want, as far as I know, neither the prop nor its materials are using relative paths, so they should work anywhere you wish. In that case, you don't need the Runtime folder, it's only used to store the files needed for the metadata.
    Regarding the material:
    • if someone thinks the wood is too dark, they can use the L.I.E editor to tweak the color mask (it's currently pure black with a 50% transparency) or replace it with any wood textures of their liking.
    • Daz Studio Default Ressources needs to be installed, because I used the Cast Iron and Walnut Semi-Gloss shaders. I don't know if there is minimal version required.
    380 x 494 - 55K
    zip
    zip
    Old_Cast_Iron.zip
    204K
    Post edited by Elor on
    edited July 3
    Here is the DIM package.
    As the prefix is 7 chars max, it is set to R&T. The product name is R&T Unseen Old Cast Iron.
    zip
    zip
    RT08485703-01_RTUnseenOldCastIron.zip
    201K
    Very happy to see my little bit of work has been improved upon. Regards, Richard.
    I love the final render. The shaders are very nicely chosen. Thank you for the credit and for repckaging and improving the whole thing.:)
