Downloading latest DAZ?
Hi all, I have been trying for days (ever since it first was announced)  to download DAZ 6 through DIM, but the instant it starts to download, it stops and says Retry. Almost like the link itself is broken. Any ideas please? Thanks! (I have checked for space on the drive - there is plenty.)
  • felisfelis Posts: 6,656
    The servers can sometimes be unstable and require you to wait and try again. But it sounds as if you have already done that.
    If you in DIM click the gear icon and 'Show log', does the log then have any usefull information?
  • 3DScreencraft3DScreencraft Posts: 509
    Hi, thanks for replying - there's a lot of data in the log which I don't understand, the only thing that is repeated over and over is a keep alive request, then that it was successful. The last time I tried the DS 6 download, this is the log result (just for the DS6) - I don't know what "range not satisfiable" means?
    2026-06-25 09:31:22.839 [INFO] :: Requesting: 89908-2 : Daz Studio 6 (Win 64-bit)
    2026-06-25 09:31:24.395 [VERBOSE] :: Redirected Request: 89908-2 : Daz Studio 6 (Win 64-bit)
    2026-06-25 09:31:24.523 [WARNING] :: Network Error: 416 - Range Not Satisfiable : Error downloading https://sdn.daz3d.com/file/dazsdn/p/08/89908/zip/1780515657/IM00089908-02_DazStudio6Win64bit.zip?auth=1782376286-h2ZnV1f3nPTirkr2MMFALYXsbupvU4p22Uu9hFbpzT0= - server replied: Range Not Satisfiable
    2026-06-25 09:32:22.988 [VERBOSE] :: Requesting keep-alive...
    2026-06-25 09:32:23.171 [VERBOSE] :: Keep-alive successful
    2026-06-25 09:32:23.171 [VERBOSE] :: Requesting current notification data...
    2026-06-25 09:32:23.171 [VERBOSE] :: Requesting default notification data...
    2026-06-25 09:32:23.436 [VERBOSE] :: Local cache contains default notification data
    2026-06-25 09:32:23.496 [VERBOSE] :: Local cache contains current notification data
    2026-06-25 09:37:23.175 [VERBOSE] :: Requesting keep-alive...
    2026-06-25 09:37:23.473 [VERBOSE] :: Keep-alive successful
    2026-06-25 09:37:23.474 [VERBOSE] :: Requesting current notification data...
    2026-06-25 09:37:23.474 [VERBOSE] :: Requesting default notification data...
    2026-06-25 09:37:23.759 [VERBOSE] :: Local cache contains default notification data
    2026-06-25 09:37:23.882 [VERBOSE] :: Local cache contains current notification data
    2026-06-25 09:42:23.471 [VERBOSE] :: Requesting keep-alive...
    2026-06-25 09:42:23.734 [VERBOSE] :: Keep-alive successful
    2026-06-25 09:42:23.734 [VERBOSE] :: Requesting current notification data...
    2026-06-25 09:42:23.735 [VERBOSE] :: Requesting default notification data...
    2026-06-25 09:42:23.981 [VERBOSE] :: Local cache contains default notification data
    2026-06-25 09:42:24.051 [VERBOSE] :: Local cache contains current notification data
    2026-06-25 09:44:18.586 [VERBOSE] :: Checking session ID validity...
    2026-06-25 09:44:18.748 [VERBOSE] :: Session ID valid
  • sidcarton1587sidcarton1587 Posts: 118
    That specific error suggests that the server download was interrupted for some reason and DIM couldn't resume the download because the the starting point for the resume didn't match what the server was expecting.
    I had similar constant Retry issue and it turned out I needed to temporarily set the DIM Downloads directory to a local drive instead of a remote one (in this case, a different machine where all my downloads normally live)
  • memcneil70memcneil70 Posts: 6,211
    Utah and Colorado have some major electrical storms going through them yesterday and today. I woke at 1am MDT to thunder and found out that 12,000 folks around Colorado had lost power from high winds, tornadoes, hail, flooding. Utah may have some of the same issues as the storms are coming from the west of us. We had a power interruption about an hour ago and everything had to be reset here.
