Loading new clothes into a scene automatically fits onto a figure?
Hi, I'm not sure why I'm having this issue. In the past I was able to load a clothing item into the scene without it automatically fitting onto a figure. I'm not sure if I accidentaly hit some setting but if I have a single figure loaded, merging new clothes into the scene will automatically fit onto the figure even if I have nothing selected into the viewport.
How do I prevent this?
Thanks,
  • SixDsSixDs Posts: 2,384
    That is not normal behaviour. Are you quite certain that you do not have the figure selected in the scene? You can check this for certain by looking under the Scene tab. Expand the view for the figure. Having any part of the figure selected will trigger autofit.  Nothing there should be highlighted if there is nothing selected.
    Yes, certain on that end. I've been using Daz for 7 months and first time have run into this issue about two days ago. Restarting PC doesn't solve the issue. It happens on new scenes with new figures as well so it's not persistant to the save file. Only workaround I've found is to manually drag the clothing into the scene, since merge still fits it.
  • vamokvamok Posts: 246
    edited June 22
    I am trying to install some assets from Renorosity using Content Wizard. It automatically clears the scene before loading in the clothing item, and yet the autofit dialogue box pops open, and the installation complete box pops up at the same time. Then I can't close either dialogue box and I have to shut Daz down because I am stuck with two boxes open.
    I have been using Daz for years and Content Wizard since it came out. This is the first time I have used it with the newest version of Daz4. It will not even run in Daz 6.
    Edit: It had popped open multiple autofit boxes, but the other ones were on a differnet monitor behind a window. I was able to close them all and continue, but this is a new unwanted behavior with autofitting, because it still forces me to cancel out of Content Wizard after each clothing install.
    Edit #2: The first item loads in and then it does not clear like it used to. Then the next item loads in as a child of the first item (causing the autofit box to open). Each new part of the outfit loads in as a child and tries to autofit to the original garment.
    Post edited by vamok on
