DazStudio To GLB exporter Testers Wanted
So i'm creating a DazStudio dsa script that exports from daz to glb formate nothing extra is needed for it to work just the single script and DazStudio which I currently have it running in Daz4.2X and Daz6.0 I have no other versions on my end to test. and what this can do so far is pretty huge in itself, why I need a couple testers I have stuff mainly for G8 and don't use 8.1, 9 or any of the others and i'm curiuse how it will work for other users
I included a list of everything it's currently capable of but the main thing that made me want want to build this is that Daz does not really support exporting merged anatomy with full moph support and this does it really well check out the list below for all the features
This exporter can:
* **Export DAZ models to GLB/glTF**
* `.glb` single file
* **Export character geometry**
* body mesh
* clothing
* hair
* eyelashes
* accessories
* fitted items
* **Export props and environments**
* rooms
* furniture
* scene props
* static environment meshes
* grouped/null-parented scene objects
* **Export rigging**
* bones
* skeleton hierarchy
* skin weights
* inverse bind matrices
* skinned meshes
* **Export morph targets**
* figure morphs
* clothing morphs
* attachment morphs
* anatomy/geograft morphs
* **Export animation**
* BVH skeletal animation
* root/hip translation
* DAZ morph animation
* environment mesh animation as morph-cache targets
* **Handle geografts/anatomy**
* export grafts separately
* merge grafts/anatomy into the body
* remove hidden/overlapping body faces
* smooth seams
* harmonize skin-like materials
* **Handle clothing/body cleanup**
* remove body polygons under clothing
* reduce poke-through
* repair or rebuild fitted clothing weights
* **Export materials**
* DAZ/Iray-to-glTF PBR conversion
* base color
* roughness
* metallic
* normal maps
* emissive maps
* opacity/cutout materials
* glass/wet/eye material handling
* **Export and process textures**
* embed textures in GLB
* resize textures
* bake opacity maps into PNG alpha
* include or skip character/environment textures separately
* **Exclude specific content**
* exact-name exclusion for nodes, meshes, objects, shapes, geometry, materials, and surfaces
* wildcard exclusions when wanted
* **Generate helper lists**
* mesh/node/surface name list
* morph target list
* bone hierarchy tree
* **Save presets**
* full exporter settings
* morph lists
* exclusion lists
* anatomy merge lists
* environment animation lists
Updated with link to anyones who wants to try it
https://drive.google.com/drive/folders/1bSCZKy6I030F71l56IRMQ7j8qA9FPGnY?usp=sharing
Hey, I'm trying to do that exact export right now! Using 8.1 currently. Let me know if you want to share the script
Definately something of interest.
I actually have glTF 2 export in my shattering plugin, tailored for the plugin of course, but very cool stuff man. Any examples?
Where is the shattering plugin available?
The link only shows the png images not the script or plugin files.
open the studiobridge folder copy the 2 files in there into your scripts folder in daz then run the script from your scripts folder
It is currently submitted here at DAZ still in PASS.
Thanks for sharing, the script file is now showin in the folder. You may want to create a document folder and move the png image files into that folder to reduce the confusion.
Interesting enough there is too much information in a single interface. Consider making Tabs for the various sections and have the user reference the readme document for further information.
First run, the aniamtion did not export. On a read through it appears the user will have to export the animation as BVH and reimport into the tool for it to work, lets discuss. I sent you a PM.
Thanks for the update.
This is the image of an updated DS6 version of Daz Widget Tester as a sampler. I have not shared the code, I'll wait on Rechards response before moving forward.
Nice, is that for addition to the SDK examples? I don't want to derail the OPs thread, we can chat via PM if you like.
This script is AI generated so it is going to need alot of cleanup. Not knocking AI, it has its uses.
Here is the code for the Widget Sampler, the original is an old Daz code updated to work in DS6.
// DAZ Studio version 6.25.2026.12107 filetype DAZ Script
File: widgetTest.dsa
Copyright (C) 2002-2010 DAZ Productions. All Rights Reserved.
This file is part of the DAZ Script Documentation.
This file may be used only in accordance with the DAZ Script
license provided with the DAZ Script Documentation.
The contents of this file may not be disclosed to third parties,
copied or duplicated in any form, in whole or in part, without the
prior written permission of DAZ Productions, except as explicitly
allowed in the DAZ Script license.
See http://www.daz3d.com to contact DAZ Productions or for more
information about DAZ Script.
var oSTYLE = App.getStyle();
var nMARGIN = oSTYLE.pixelMetric( "DZ_GeneralMargin" );
var nSPACING = nMARGIN;
var nMIN_BTN_WIDTH = oSTYLE.pixelMetric( "DZ_ButtonMinWidth" );
var nMAX_BTN_HEIGHT = oSTYLE.pixelMetric( "DZ_ButtonHeight" );
var clrBLACK = new Color( 0, 0, 0 );
var clrWHITE = new Color( 255, 255, 255 );
var clrRED = new Color( 255, 0, 0 );
var clrGREEN = new Color( 0, 255, 0 );
var clrBLUE = new Color( 0, 0, 255 );
// Get the Help Manager for "What's This?" and tool tips
var oHelpMgr = App.getHelpMgr();
// find the "What's This?" action; for the help button
var oActionMgr = MainWindow.getActionMgr();
var oHelpAction = oActionMgr ? oActionMgr.findAction( "DzWhatsThisAction" ) : undefined;
Dialog
var wDlg = new DzDialog;
wDlg.caption = "DAZ Script Widget Test";
// Main Layout
var wDlgLyt = new DzVBoxLayout( wDlg );
wDlgLyt.autoAdd = true;
wDlgLyt.margin = nMARGIN;
wDlgLyt.spacing = nSPACING;
// Create a check box
var wBtn = new DzCheckBox( wDlg );
wBtn.text = "DzCheckBox 0";
// Create a combo box
var wComboBox = new DzComboBox( wDlg );
wComboBox.insertItem( "DzComboBox Item 0" );
wComboBox.insertItem( "DzComboBox Item 1" );
wComboBox.insertItem( "DzComboBox Item 2" );
wComboBox.currentItem = 1;
// Create a date edit
var wDateEdit = new DzDateEdit( wDlg );
wDateEdit.date = new Date;
// Create a time edit
var wTimeEdit = new DzTimeEdit( wDlg );
wTimeEdit.date = new Date;
// Create a date time edit
var wDateTimeEdit = new DzDateTimeEdit( wDlg );
wDateTimeEdit.date = wDateEdit.date;
// Create a group box
var wHBox = new DzHGroupBox( wDlg );
// Create a dial
var wDial = new DzDial( wHBox );
wDial.minWidth = 100;
wDial.minHeight = 100;
wDial.min = 0;
wDial.max = 255;
wDial.notchesVisible = true;
wDial.notchTarget = nSPACING;
wDial.wrapping = false;
// Create a LCD number
var wLCD = new DzLCDNumber( wHBox );
wLCD.value = wDial.value;
wLCD.segmentStyle = wLCD.Flat;
setLCDValue( wDial.value );
function setLCDValue( nValue )
wLCD.value = nValue;
if( nValue < 85 )
wLCD.paletteForegroundColor = clrRED;
else if( nValue < 170 )
wLCD.paletteForegroundColor = clrGREEN;
else
wLCD.paletteForegroundColor = clrBLUE;
connect( wDial, "valueChanged(int)", setLCDValue );
// Create a color widget
var wColor = new DzColorWgt( wDlg );
wColor.value = clrRED;
// Create a int slider
var wSlider = new DzIntSlider( wDlg );
wSlider.min = 0;
wSlider.max = 9;
wSlider.clamped = true;
wSlider.sensitivity = 1;
wSlider.value = 2;
wSlider.textEditable = true;
wSlider.textVisible = true;
// Create a enum slider
wSlider = new DzEnumSlider( wDlg );
wSlider.addItem( "Zero" );
wSlider.addItem( "One" );
wSlider.addItem( "Two" );
wSlider.addItem( "Three" );
wSlider.addItem( "Four" );
wSlider.addItem( "Five" );
wSlider.addItem( "Six" );
wSlider.addItem( "Seven" );
wSlider.addItem( "Eight" );
wSlider.addItem( "Nine" );
wSlider.value = 2;
// Create a float slider
wSlider = new DzFloatSlider( wDlg );
wSlider.min = 0;
wSlider.max = 9;
wSlider.sensitivity = 0.5;
wSlider.value = 2;
// Create a button group
var wBtnGrp = new DzVButtonGroup( wDlg );
wBtnGrp.title = "DzVButtonGroup";
wBtnGrp.columns = 2;
wBtnGrp.title += String( " (columns = %1)" ).arg( wBtnGrp.columns );
wBtnGrp.checkable = true;
// Create some radio buttons
wBtn = new DzRadioButton( wBtnGrp );
wBtn.text = "DzRadioButton 0";
wBtn.text = "DzRadioButton 1";
wBtn.text = "DzRadioButton 2";
wBtn.text = "DzRadioButton 3";
wBtn.text = "DzRadioButton 4";
wBtn.text = "DzRadioButton 5";
wBtnGrp.selected = 3;
// Create a label
var wLbl = new DzLabel( wDlg );
wLbl.text = "This is a DzLabel.";
// Create a line edit
var wLineEdit = new DzLineEdit( wDlg );
wLineEdit.text = "DzLineEdit Highlighted";
wLineEdit.setSelection( 11, wLineEdit.text.length - 1 );
// Create a listbox
var wListBox = new DzListBox( wDlg );
wListBox.insertItem( "DzListBox Item 0" );
wListBox.insertItem( "DzListBox Item 1" );
wListBox.insertItem( "DzListBox Item 2" );
wListBox.setSelected( 1, true );
// Create a listview
var wListView = new DzListView( wDlg );
wListView.rootIsDecorated = true;
wListView.allColumnsShowFocus = true;
wListView.addColumn( "Column 0" );
wListView.addColumn( "Column 1" );
var wListviewItem;
for( var i = 0; i < 3; i++ )
wListViewItem = new DzListViewItem( wListView );
wListViewItem.setText( 0, String( "DzListViewItem %1" ).arg( i ) );
var wListViewItemChild;
for( var j = 0; j < 3; j++ )
wListViewItemChild = new DzListViewItem( wListViewItem );
wListViewItemChild.setText( 0, String( "DzListViewItem %1 Child %2" ).arg( i ).arg( j ) );
// Create a group box for the dialog buttons
var wDlgBtnsGB = new DzGroupBox( wDlg );
wDlgBtnsGB.flat = true;
// Create a layout for the dialog buttons
var wDlgBtnsLyt = new DzGridLayout( wDlgBtnsGB );
wDlgBtnsLyt.margin = nMARGIN;
wDlgBtnsLyt.spacing = nSPACING;
// Create the interactive help ("What's This?") push button
var wHelpBtn = new DzPushButton( wDlgBtnsGB );
wHelpBtn.pixmap = new Pixmap( String( "%1/images/icons/whatsthissmallicon.png" ).arg( App.getResourcesPath() ) );
wHelpBtn.maxHeight = nMAX_BTN_HEIGHT;
if( oHelpAction )
wHelpBtn.clicked.connect(function() { oHelpAction.activate(); });
wHelpBtn.toolTip = oHelpMgr.getToolTip( "WhatsThis" );
wHelpBtn.whatsThis = oHelpMgr.getHelpString( "WhatsThis" );
wDlgBtnsLyt.addWidget( wHelpBtn, 0, 0 );
// Stretch the column between the left and right sides
wDlgBtnsLyt.setColStretch( 1, 1 );
// Create the accept push button
var wAcceptBtn = new DzPushButton( wDlgBtnsGB );
wAcceptBtn.text = "&Accept";
wAcceptBtn.minWidth = nMIN_BTN_WIDTH;
wAcceptBtn.maxHeight = nMAX_BTN_HEIGHT;
wDlg.setAcceptButton( wAcceptBtn );
wAcceptBtn.toolTip = oHelpMgr.getToolTip( "AcceptDialog" );
wAcceptBtn.whatsThis = oHelpMgr.getHelpString( "AcceptDialog" );
wDlgBtnsLyt.addWidget( wAcceptBtn, 0, 2 );
// Create the cancel push button
var wCancelBtn = new DzPushButton( wDlgBtnsGB );
wCancelBtn.text = "&Cancel";
wCancelBtn.minWidth = nMIN_BTN_WIDTH;
wCancelBtn.maxHeight = nMAX_BTN_HEIGHT;
wDlg.setRejectButton( wCancelBtn );
wCancelBtn.toolTip = oHelpMgr.getToolTip( "CancelDialog" );
wCancelBtn.whatsThis = oHelpMgr.getHelpString( "CancelDialog" );
wDlgBtnsLyt.addWidget( wCancelBtn, 0, 3 );
// Polish
wDlg.width = wDlg.minWidth > 400 ? wDlg.minWidth : 400;
wDlg.height = wDlg.minHeight;
// Launch
wDlg.exec();
