How can I make DS4 Default
Hey,
I downloaded DS6 because I wanted to try out and see how it is, I won't however switch to DS6 just yet, but now when I open files through file explorer DS6 launches instead of DS4. My question is how can I make it so for now DS4 is default until I actually want to switch over?
  • LeanaLeana Posts: 13,640
    Under windows you can define the default application used for a file type in the application settings.
    Another option is to right-click a file then select "open with", then after pointing to DS6 you select "always open with this application".
  • Viper141Viper141 Posts: 29
    Hi, I tried this but it keeps selecting DS6, despite me repetadly selecting the DS4 launch area.
  • crosswindcrosswind Posts: 10,353
    edited June 14
    You can refer to this thread to fix it : https://www.daz3d.com/forums/discussion/757871/can-t-replace-daz-4-normal-app-with-public-build-as-standard-app-for-duf-files
    i.e. simply replace "C:\Program Files\DAZ 3D\DAZStudio6\DAZStudio.exe" "%1" with
    "C:\Program Files\DAZ 3D\DAZStudio4\DAZStudio.exe" "%1"
    Or, re-installing DS4 should be able to fix it as well ~~
    Post edited by crosswind on
    Thank you, this seems legit. Will give this ago! If I don't send another message I probably fixed it. Thank you again!
