Adding to Cart…
I'm having a problem with dForce2morph. When I save it on hair, it detaches from the figure. I'll use a default gf8 as an example. In the first 2 images I run the simulation, things go just fine. I save the hair in the last frame as a morph, which clears the simulation. I return to the frame it was saved onto and apply the morph. And it floats off of the figure.
The hair is a mesh, not a strand based thing.
Leaving this here in case anyone else stumbles on it looking for answers.
I was able to reproduce an issue where this script was not working
1. Issue appeared becouse my Windows user name included latin-ext characters. If yours does too you'll need to move your daz setup over to different profile (script has problems reading paths with special characters, I assume this could be fixed).
2. Another issue i found was that I've disabled Poser in plugins. Seems like DAZ is unable to import obj files w/o Poser plugin on, so if your Poser plugin is off re-enable it and restart DAZ.
