Any know how to uninstall Daz 6
In DAS installman it doesn't appear in the installed items. It just keeps repeating install, wanting to install.
It doesn't appear in Windows 11 uninstall apps.
  • MasterstrokeMasterstroke Posts: 2,447
    DAZ Studio 6 and DAZ Studio 6 BETA don't have a uninstall log file.
    A true embarrassing beginner's mistake.
  • Richard HaseltineRichard Haseltine Posts: 110,836
    They can be uninstalled from the Installed tab of DIM (click the Uninstall button, or multi-select and click the Start Queue  button), since that was used to install them. You wouldn't want everything DIM installed added to the system list.
  • MaverickMaverick Posts: 47
    No, it's not in there, all I get in the daz 4.
    I dind't know it was beta, and begininger.. No!
    After installation it is listed in the installed section of the DIM.
    Uninstall does nothing, for there is no folder called "uninstall" created in the DAZStudio 6 file hirachy.
    Same for DAZStudio 6 BETA. It cannot be unistalled by Windows either.
    It uses the manifest file to uninstall. DIM, installed through Windows, has an uninstallers folder, no version of DS, installed through DIM, does. if you are not getting an uninstall opton n DIM then that s an issue, but t is not caused by the lack of an Uninstallers folder.
  • brainmuffinbrainmuffin Posts: 1,321
    What about the beta version? I have DAZ Studio 4 and 6 listed in DIM, but not the Beta.
  • DireWorksDireWorks Posts: 135
    did you checked the release channels tags in download filters?
  • keremgo3dkeremgo3d Posts: 17
    edited June 20
    I just had to Format C:/s and re-installed Windows 10 and DAZ Install Manager (I don't like the new installer thing with big window). I let it install all the stuff but DAZ 6 installed with content instead of DAZ 4+ -- if I uninstall DAZ 6, would it break the installed content too? :-/
    Post edited by keremgo3d on
  • felisfelis Posts: 6,410
    Content is independant of programs (you need to setup the right content path if reinstalling).
    You should be able to have DS4, DS4beta, DS6 and DS6 beta independant of each other, where you can install and uninstall as you like.
    THANK YOU SO MUCH!
