Help finding a few things in Daz 6
I can't find any of the Premier tools. I have closed and restarted Daz 6 multiple times, but the Premier tools like Geometry Sculptor do not show up. Also, under edit/preferences/interface, you used to be able to hide the select lesson strip, but I no longer see that option.
  • joshua.r.fletcherjoshua.r.fletcher Posts: 113
    edited June 4
    Try registering your Daz.  Help ->Register Daz Studio.  Get your code from "My Account"->Serial Numbers here on the Daz site.  Once applied, you'll need to restart Daz to see them.
    Post edited by joshua.r.fletcher on
  • clesszorclesszor Posts: 6
    Yes i confirm. It is impossible to register and get all "premier features" into DAZ 6. I register with my premier daz account and nothing... Any help ?
  • crosswindcrosswind Posts: 10,358
    edited June 5
    1. Premier plugins need to be installed via DIM first of all, after DS 6 is installed there. Then check under the folder: C:\Program Files\DAZ 3D\DAZStudio6\plugins, to see if the Premier plugins are well installed (screenshot 1)
    2. Then, you don't need to register DS 6 or any Premier plugins but you have to Login to Daz Connect to verify your Premier membership, via DS > Smart Content > Login. Hang on for 1 ~ 2 minutes after Login... till you can find a Premier logo via Help > About Daz Studio...
    3. Close and relaunch DS (Premier logo will shown on DS splash screen...). You should be able to find activated Premier plugins under Window > Panes... or Help > About Installed plugins...
    Enable / Disable Lession Strip has never been under Preferencess (F2). You can disable it via : Window > Workspace > Enable Lession Strip.
    1007 x 1286 - 116K
    Post edited by crosswind on
  • Kev914Kev914 Posts: 1,153
    So is there no mesh grabber? i found the Premier plugins for version 6 and install them. I didn't see Mesh Grabber.listed. It doesn't show up on the tool settings menu. Also Pose Converter shows that it was installed and it is listed in the directory you show above, but I can't find it in the program. It use to be under the script men I believe in version 4.
    Thanks
    I found Pose Converter under the Edit\Figure Menu. I don't remember it being there on version 4. Still can't find mesh grabber.
    OK. I see that it's now called Geometry Sculpt now. Guess I missed the meno.
    Yup, that's it.
