Here is a cube with the glass shader part of default ressources.
The issue as I see it, is if an object has 100 % refraction, it will be invisible in texture shaded, no matter refraction index or colors.
Glass only show's it's reflection. If you want to see it outside of reflection you can set "Max Refraction Weight" in draw settings to a value less than 1 or you can use universal and set it's override to wireframe.
Why is the Viewport Texture Shaded still single and lonely? A 3D artist girl's case with "lazy" processor threads...
Hi everyone!
I’d love to get some clarity on Viewport performance, because working in Texture Shaded mode lately feels like a bit of an unpredictable adventure. I’m honestly pulling my hair out due to the constant slideshow effect, and I’d really love to understand the whys before I go completely bald and have to wear a wig in front of the monitor.
As I’ve been digging through the technical spheres, I’ve started to get the picture: Daz—my dear, stubborn little favorite—insists on assigning just a single thread to calculate character movement and outfit adjustments, while leaving the others to rest. It’s almost as if it were saying: "We deal with one thing at a time, if you please!"
My Beast (my PC) is certainly not the latest luxury model, but it’s far from a potato: it’s a Dual Xeon system (20 cores, 40 threads) running the studio, loaded with 128 GB of RAM. In theory, it should be purring like a satisfied kitten, but instead, it acts more like a moody little tiger that only moves when it really has to.
But the thing that actually makes me smile... OH WAIT, NO! :) I’m looking at the stats, and I see a single poor thread sweating, but curiously, not even at 100%, while the other 39 threads are cheering on that one poor soul from their comfy armchairs with a beer in hand, as it tries to move that pesky character outfit. Real teamwork, right!
Is there anyone here who could be my hero and explain to a mortal artist: what is the technical reason why Daz is so loyal to this single-threaded technique in the Viewport? Is there any beautiful hope that in the future, the other threads might join in on this little game? Or, if anyone has heard any juicy gossip from the developers regarding modernization, don’t keep it to yourself—bring it on!
If anyone knows a secret spell (or just has a well-proven tip) on how I could convince my "crew" to work together, please share! I’d be very grateful!
Thanks a lot to any clever gentleman or experienced colleague who can gift me some knowledge—or at least a little bit of hope!
Unfortunately not every process can be multi-threaded - that requires that the process can be slit down into separate bits that can each be worked on without needing information from any other bit. In the case of adjusting a pose or shape then there are a lot of linked ramifications (one property that may be linked to another) and they al need to be traced through to get a final value, from which the shape can be calculated.
Two hands could let you pour water and stir at the same time. You're not gonna handwrite twice as fast with two hands though. Single vs multithreading.
I just upgraded DAZ 6 to the latest version (6.25.2026.14219) and I updated to the NVidia drivers to the very latest version (610.47 - Release: Tue May 26, 2026) and now Daz 6 won't render. See Troubleshootng info below:
2026-05-27 08:57:21.969 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(418): Iray [ERROR] - IRAY:RENDER :: 1.0 IRAY rend error: Cannot render: found no usable devices. Please update your NVIDIA driver (www.nvidia.com) to at least 576.02, or enable CPU rendering.<br />
2026-05-27 08:57:21.971 [ERROR] Iray :: Invalid parameters (null pointer).<br />
2026-05-27 08:57:22.081 [INFO] :: Saved image: C:\Users\jande\AppData\Roaming\DAZ 3D\Studio6 Public Build\temp\render\r.png<br />
2026-05-27 08:57:22.081 [INFO] :: Finished rendering.<br />
2026-05-27 08:57:22.095 [INFO] :: Total Rendering Time: 1.55 seconds
As I'm pretty sure I got an NVidia driver version >576.02 I'm at a loss here.
Should I downgrade the Nvidia driver? Or is there another solution available? Thanks for help/guidance!
Is your GPU listed in Render Settings - Hardware tab?
Yes, it is; see screenshot attached. And while looking it up, I also noticed the checkbox "Check GPU driver version". If I uncheck this, Daz 6 renders.
However, I don't think this is the correct behaviour... The new driver is newer than the required driver, so, it should not throw an error if this checkbox is checked...
It could be the actual driver itself. There have been issues in the past with new drivers, which were then fixed with the next driver update.
Hi everyone!
It may not be what you want to hear, but here goes.
Studio multithreads the update of individual figures and props in a scene when the geometry on a node is large enough to justify it. However, Studio does not currently multithread the processing of the entire scene node list due to potential inter-dependencies between nodes. They may reexamine this methodology in the future.
Techniques like breadth-first parallelization - grouping by hierarchy depth or decoupling morphing from skinning could resolve these bottlenecks without compromising data integrity.
Moving toward a more data-oriented design would allow the software to leverage modern multi-core and GPU performance, which current high-poly characters clearly demand. I hope to see the architecture evolve in this direction.
I ended up downgrading from the 5090 back to my 3090 so i could use 4.24 again, being able to work more quickly/smoothly in the viewport for production outweighed the 3x faster render times since I can queue those. $3000 paperweight sitting on my desk until things hopefully improve .
It is seriously embarassing how long this has been a problem that hasn't been fixed yet.
Whata re you meaning? DS 4 will never be able to use 50x0 cards, nVidia changed the way they compile the render engne and that cannot be used with DS 4. The only way to itengrate the iray versions required for 50x0 card support is to make changes that break compatibility with DS 4, in other words a full new version. Fortunately DS 6 was already in development and can use the versions of Iray required for 50x0 support.
What I'm refeering to is how insanely bad the viewport on the BETA is compared to DS 4, you can act like it isn't but it is, it laggs/stutters way more than DS4, and considering that is the only real option for people with newer graphic cards, and yeah its a "beta" but I would expect that they would be able to do something about it within a year, but I guess I was wrong.
No one is acting like it isn't so, but it does eem to vary from user to user - which makes it much harder to figure out what is happening and how to address it.
As far as I can see it almost every user here with a 5090 card reported that issue with the BETA. I'm one of them. Just test your own software with a 5090 card and a bigger scene and you should immediately notice the bad viewport performance compared to 4.24. Can't be that difficult.
For example using a scene in Daz Studio 6.25 with New York Stores | Daz 3D on a 5090 the camera movement becomes sluggish even without characters.
In DZ 4.24 with a 4090 everything runs smooth using the same scene. 1st pc - AMD 9800X3D + NVidia 5090; 2nd pc - AMD 5900X + NVidia 4090.
I agree with everyone complaining about viewport performance in 6.25 with a 5090. It's simply too frustrating to create scenes and pose characters with the jerky viewport. To make lemonade out of the situation I've learned to use 4.24 and 6.25 simultaneously and I kind of like it. I do pretty much everything except rendering in 4.24 and then do the rendering in 6.25. While a scene is rendering I use 4.24 to create the next scene. Of course there is a performance hit but with a high end PC it's not too bad and I suspect most people who can afford a 5090 have a pretty good PC. I know this workflow isn't for everyone because we have different needs but for story telling where characters are re-posed in the same scene a number of times it's not bad. It also has the benefit that all the scripts and plug-ins you own work in 4.24 where you do the detail work. This way you don't have to worry about script and plug-in upgrades for 6.25 and potential upgrade charges.
This next part is a naive guess on my part and if it's crazy I apologize for wasting your time. I don't know how things work 'under the hood' but if supporting the new 'Universal' view option is responsible for the performance issue then maybe it's time to back the feature out? Since 6.25 is now a beta it would be a significant setback to return to alpha but viewpart performance has to be restored. Although the universal view is a nice idea there are other ways to increase contrast between objects when the colors are too similar in texture shaded. For example, switch to cartoon shaded or filament temporarily. I miss cartoon shaded in 6.25 but filament is still available.
In which mode? I have a 5090 here, Texture Shaded seemed fine, Iray of coursedrops duriing movement but settled down as soon as I stopped, Filament also seems fine.
So you alleging that for you, the viewport of 4.24 and the BETA are pretty much the same with regards to lag/stutter? because if so, I would love to see video proof of that.
In texture shaded mode it is real sluggish espically when displaying both storefronts. It's less chucky in universal mode but also not usable. Same problem for the 4090 in DZ 6.25
Testing the same scene in Daz 4.24 everything runs smoothly.
Basically every mode is barely usable. So you're saying the viewport performance with the BETA is the same as with 4.24 on your PC? I'm sorry to say that, but that's really hard to believe. I tried the DAZ BETA on different PCs, with a fresh installed Win11 and a clean driver installation. It was always the same. Viewport performance on 4.24 was perfectly fine while it's unusable with the BETA.
Don't get me wrong, but you've got a HUGE problem here, and if it isn't fixed, I can easily imagine that, over time, MANY users will switch to other software like Blender, because as it stands now, DAZ 26 is simply unusable for everyday work.
Certainly it seems pretty mucxh the same, and perfectly adequate. I didn't time it in FPS, the non-Iray modes (including Universal) are responsive in realtime, as far as I can tell.
@Richard, do you have a dedicated card for the viewport ? Because this may make the difference over people using the same card for the viewport and rendering. Eventually, if this is the case, it may also help the developers.
p.s. Also, for everyone, stating your hardware specifications may help to understand what's the difference among systems which work and don't. Otherwise it's just complaining going blind that doesn't help the developers.
Please load two storefronts into a scene for further testing and move the camera while in universal or texture-shaded mode. I’m not writing this out of boredom. The same problem also occurs on a third system with an AMD 7940HS and a 4090 Mobile.
There are scenes where the camera movements works fluently but in other scenes I have the same problem as mentioned.
a lot of people have been specific about their hardware for a long time regarding this issue, yet it seems to be pushed aside and is never really given a straight responds from the devs. And to be honest the only one I've seen so far say that the viewport acts the same on his 4.24 and his BETA (which I don't believe for a second) is the Mod, and honestly I find that strange.
Here's my spec sheet in case it helps the developers :
MB : Z 790 X AX
CPU : i9 13900K
RAM : 64 GB DDR5
SSD : 990 Pro
GPU : RTX 5090 Astral
OS : Windows 11 64-bit
GPU driver : Nvidia Studio 610.47
The problem seems to be widespread and not limited to Daz 3D. I recently experienced disastrous performance when texturing in Substance 3D Painter; baking took four times longer with the 5090 than with my old 4070 Super... Adobe fixed the issue very recently in the latest update.
In my opinion, Blackwell is causing quite a few problems. Last year, it was impossible to bake in Substance 3D Painter for a while, and the Adobe forums were reporting similar cascading issues (which have since been resolved).
Hi everyone!
2026-05-27 08:57:21.969 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(418): Iray [ERROR] - IRAY:RENDER :: 1.0 IRAY rend error: Cannot render: found no usable devices. Please update your NVIDIA driver (www.nvidia.com) to at least 576.02, or enable CPU rendering.<br /> 2026-05-27 08:57:21.971 [ERROR] Iray :: Invalid parameters (null pointer).<br /> 2026-05-27 08:57:22.081 [INFO] :: Saved image: C:\Users\jande\AppData\Roaming\DAZ 3D\Studio6 Public Build\temp\render\r.png<br /> 2026-05-27 08:57:22.081 [INFO] :: Finished rendering.<br /> 2026-05-27 08:57:22.095 [INFO] :: Total Rendering Time: 1.55 secondsAs I'm pretty sure I got an NVidia driver version >576.02 I'm at a loss here.
Frankly IMO this was changed from Alpha to a Beta release way to soon
...so according to the "Evergreen" release thread (now closed) I take it older versions of Windows (eg. 7 and 8) are no longer being supported..
Microsoft support for Windows 7 ended on January 14, 2020 and Windows 8.1 ended on January 10, 2023. So yes, they are no longer supported.
MB : Z 790 X AX
CPU : i9 13900K
RAM : 64 GB DDR5
SSD : 990 Pro
For the viewport lag users, are you using the NVIDIA Game or Studio Driver?
