(Need Help) Dicktator trouble with G8M
I need help. From yesterday to today, this happened when I loaded a G8.1M figure with Dicktator. I've already uninstalled and reinstalled it and nothing solves it, I even reinstalled the G8M starter and the problem persists. What caused this? I don't know how to solve it anymore and I need help please. I've made many scenes and in all of them the Dicktator shell simply doesn't apply the materials. In the surfaces tab, the "Shaft, Glans, Testicles" fields don't appear, instead all surfaces are blank and without material. I don't know what else to do and I need help.
I know I can't post NSFW images, but I tried to pin the image to the problem, with no intention of breaking any rules. My log file is attached.
  • Richard HaseltineRichard Haseltine Posts: 111,472
    What is the issue? If it isn't grafting properly check which tool is active - content creation tools, such as Mesh Grabber/Geometry Sculptor, turn off grafting and hiding of faces so that you can edit properly; if that is the issue switching back to a node selection tool, such as the Universal tool, should resolve the problem.
    If it is that the shell is opaque, do you have any other grafts or other products that use shells loaded onto the figure?
  • lilweeplilweep Posts: 2,873
    did you load the Geograft onto the figure? Or did you load the Geograft into a the screne by itself.  In your screenshot it is detached from the figure.
    Select the Geograft and go into Paramters tab and go to "Fitted to..." and ensure it is attached to G8.1M figure
    Your use of the word shell only is suspicious. As I understand, the Dicktator materials involve both the actual Geograft mesh and the overlying Geoshell.
    Lack of materials applied to Shell is not the only problem you are showing in your screenshot.
    You are showing 3 problems:
    1) The geograft not attaching to the figure
    2) Materials not applied to the Geograft
    3) Materials not applied to Geoshell.
    Screenshot?
    The Surfaces tab is context dependent. It will show the Surfaces for the thing you have selected. If you have not selected anything, it will not show anything.
    Ensure you have selected in the Scene tab the Geograft or Geoshell, depending what you want to inspect
    1. When applying the Geograft, select the G8.1M figure in the scene before loading it into scene so that it attaches to the selected.  Or update "Fitted to..." in the paramaters page.  Or as richard said ensure you are not on Geometry Editor tool etc.
    2. Follow the exact steps for applying materials, using the instructions that are included with the product.  The operations should be done in order and they may involve you actually clicking the appropriate thing in the Scene tab
