Coming soon: Voronoi (and more) Shatter Tool for DAZ Studio [Commercial]
umblefuglyumblefugly Posts: 84
Coming Soon: Voronoi (and more) Shatter Tool for DAZ Studio
A DAZ-native fracture and debris tool for breaking props, glass, stone, wood, walls, and impact objects directly inside DAZ Studio.
Teaser Feature List
  • Static mesh shattering directly in DAZ Studio
  • PhysX-based fracture simulation
  • Bakeable animated debris results
  • Multiple fracture styles:
    • Uniform chunks
    • Local impact breaks
    • Radial burst patterns
    • Wood splinters
  • Fast and Robust shatter backends
  • Material preservation for generated shards
  • Custom inside fracture colors and textures
  • Mesh Prep tools for cleaner shatter results
  • Close Holes / repair support for problem meshes
  • Per-object simulation controls
  • Break on impact, frame, force, or proximity
  • Explosion, radial, directional, and upward burst shard motion
  • Static shard push-apart for quick visual previews
  • Simulation cleanup tools
  • Save and load sim package setups
  • glTF 2.0 export
  • Designed for DAZ Studio artists who want destruction workflows without leaving DAZ
Break it. Sim it. Bake it. All inside DAZ Studio.
Note: Initial release support is planned for DAZ Studio 4.24.0.x. Support for the 2026 DAZ Studio SDK will be evaluated after the SDK/API stabilizes.
Post edited by umblefugly on
  • backgroundbackground Posts: 805
    Sounds interesting. How much is it influenced by the existing topology of the object that you put into it?
  • umblefuglyumblefugly Posts: 84
    edited May 18
    For the current V1 shatter system, the fracture pattern is not driven by the original mesh topology in the way a pre-cut polygon modeler would be. It is driven mainly by:
    • the generated seed points
    • the chosen pattern: Uniform, Local, Radial, Splinters
    • impact point / radius where applicable
    • backend: Fast or Robust
    • the source mesh volume/bounds/surface intersection
    • mesh prep result
    So a cube with 12 triangles and a cube with many clean coplanar subdivisions should generally produce the same kind of shatter if their shape, scale, settings, and watertightness are equivalent.
    But topology still matters for reliability and cleanup:
    • It should be watertight/closed for best results.
    • Non-manifold edges can confuse inside/outside and cap generation.
    • Self-intersections or internal shells can create bad shards.
    • Extremely thin geometry has special behavior and higher risk.
    • Bad normals, duplicate faces, degenerate triangles, or unwelded seams can affect mesh prep and cap quality.
    • UV/material slots affect material preservation, not the actual fracture pattern.
    • Organic/Genesis-style internal geometry remains a risk case but thus far has no issues.
    So the short version: topology does not artistically control the fracture layout right now; geometry shape and settings do. But bad topology can still make the fracture fail, generate unsafe boundary cases, or require fallback cleanup.
  • SorelSorel Posts: 1,420
    Hell yeah, looking forward to this.
    Me too lol. I'm just working on some speedups, its pretty fast right now, 2000 pieces simulated over 60 frames CPU shatter + GPU for PhysX + full material/shader copy takes just under 30 seconds on a 10900k, 64 GB DDR4, and a 3090 Ti.
    1920 x 1080 - 1M
  • jjoynerjjoyner Posts: 796
    This looks interesting.  I find that too many of the products that feature broken building, etc. are too clean in their breaks.  Based on the three images that you uploaded, it looks like your product will improve on the broken look of objects.
    Yes, for version 1 I just want to lay the groundwork for basics, then if theres enough interest Id like to eventually get it to do more stuff like Pulldownit, RayFireTool,FractureFX etc. for a legit destruction pipeline for DS.
    If anyone is interested in reading, I can share the usermanual.
    Yes, I'd like t take a look at it.
    *Raises hand*
    edited 1:35PM
    Here is the manual for now, there may still be additions/edits. Updated the manual here as well.
    pdf
    pdf
    Voronoi_Shatter_Tool_User_Manual.pdf
    1M
    Post edited by umblefugly at
    edited 4:07PM
    Genesis 9 mesh healed, preshattered with projectiles using nulls as target/impact locations.For higher speed projectiles you may need to increase FPS to mitigate any contact offsets i.e. projectile affecting the shattered mesh before impacting.
    Another example preshattered mossy statue, dynamic only.
    1920 x 1080 - 1M
    1920 x 1080 - 2M
    Do you have a general idea of when you'll be submitting this to daz?
    edited 4:30PM
    Even if I submitted it today, the way things are going now, it could be a month and a half away from hitting the store, so I cant give an exact date. I am still making last minute quality changes as well as updating the manual. Props, scenes and Companion script are relatively finished.
    edited 6:48PM
    Couple more. Barrel "Blast" splinters shatter "Statue". Simulation speeds will slow down a lot when you use heavy meshes with lots of materials. That scene is 173,000 polygons.
    1920 x 1080 - 2M
    1920 x 1080 - 2M
