Loading issue with the “Z in the shower” content
axionescyllas
Hello!
https://www.daz3d.com/z-in-the-shower-pose-mega-set-for-genesis-9-8-and-81-female
So I bought the product, installed it with DIM, but it doesn't work. I uninstalled it and reinstalled it with DIM, but the same thing happened. I tried installing it directly in Daz Studio, but nothing worked.
I checked the files—everything is in the right place.
I also tried converting the G8 poses to G9, but nothing works.
I also quit and restarted after reinstalling and tried it on an older G9.
What can I do?
Here is my log file:
2026-05-10 10:08:47.790 [WARNING] :: \src\sdksource\cloud\dzcloudtasknotifier.cpp(203): Invalid reason for encrypted file: "E:/Daz 3d/My DAZ connect library/data/cloud/1_93624/people/genesis 9/poses/zeddicuss/z in the shower/01 full body/z intsh full 20 g9f standing washing legs.duf.enc"
2026-05-10 10:08:47.790 [WARNING] :: \src\sdksource\cloud\dzcloudtasknotifier.cpp(203): Invalid file header for encrypted file: "E:/Daz 3d/My DAZ connect library/data/cloud/1_93624/people/genesis 9/poses/zeddicuss/z in the shower/01 full body/z intsh full 20 g9f standing washing legs.duf.enc"
2026-05-10 10:08:47.790 [ERROR] :: Open Stream Error - No stream for CloudFile: E:/Daz 3d/My DAZ connect library/data/cloud/1_93624/people/genesis 9/poses/zeddicuss/z in the shower/01 full body/z intsh full 20 g9f standing washing legs.duf.enc
2026-05-10 10:08:47.790 [ERROR] :: Open File Failed - Could not read asset information: /people/genesis 9/poses/zeddicuss/z in the shower/01 full body/z intsh full 20 g9f standing washing legs.duf
2026-05-10 10:08:48.574 [INFO] :: Prepare asset load (merge): /People/Genesis 9/Poses/Zeddicuss/Z In The Shower/01 Full Body/Z INTSH Full 20 G9F Standing Washing Legs.duf
2026-05-10 10:08:48.574 [INFO] :: Locking viewport redraw...
2026-05-10 10:08:48.574 [INFO] :: Viewport redraw locked.
2026-05-10 10:08:48.673 [VERBOSE] :: Native format content directories: 5
2026-05-10 10:08:48.673 [VERBOSE] :: Poser format content directories: 3
2026-05-10 10:08:48.673 [VERBOSE] :: Other import format content directories: 0
2026-05-10 10:08:48.673 [INFO] :: Begin asset load (merge): /People/Genesis 9/Poses/Zeddicuss/Z In The Shower/01 Full Body/Z INTSH Full 20 G9F Standing Washing Legs.duf
2026-05-10 10:08:48.673 [WARNING] :: \src\sdksource\cloud\dzcloudtasknotifier.cpp(203): Invalid reason for encrypted file: "E:/Daz 3d/My DAZ connect library/data/cloud/1_93624/people/genesis 9/poses/zeddicuss/z in the shower/01 full body/z intsh full 20 g9f standing washing legs.duf.enc"
2026-05-10 10:08:48.673 [WARNING] :: \src\sdksource\cloud\dzcloudtasknotifier.cpp(203): Invalid file header for encrypted file: "E:/Daz 3d/My DAZ connect library/data/cloud/1_93624/people/genesis 9/poses/zeddicuss/z in the shower/01 full body/z intsh full 20 g9f standing washing legs.duf.enc"
2026-05-10 10:08:48.674 [ERROR] :: Open Stream Error - No stream for CloudFile: E:/Daz 3d/My DAZ connect library/data/cloud/1_93624/people/genesis 9/poses/zeddicuss/z in the shower/01 full body/z intsh full 20 g9f standing washing legs.duf.enc
2026-05-10 10:08:48.674 [ERROR] :: Open File Failed - Could not read file: /People/Genesis 9/Poses/Zeddicuss/Z In The Shower/01 Full Body/Z INTSH Full 20 G9F Standing Washing Legs.duf
2026-05-10 10:08:48.674 [WARNING] :: Error loading asset: E:/Daz 3d/My DAZ connect library/data/cloud/1_93624/people/genesis 9/poses/zeddicuss/z in the shower/01 full body/z intsh full 20 g9f standing washing legs.duf.enc
Operation failed
Your errors relates to your Connect install (inside Daz Studio). It looks like it can't correctly decode the file. And as long as you have the Connect install it takes priority.
If you uninstall with Connect, what does the log then say?
I have that pose set and can confirm that it seems to work fine when installed via DIM alone.
That's exactly the pose I wanted XD
Hello Felis, and thanks ! So I uninstalled it via DAZ Connect and made sure everything was completely removed; I also uninstalled it using DIM :p
So the destination folder is gone!
And so I reinstalled it using DIM, and thank you! It works! :)
Problem solved :)
