Clicking on body part has stopped working.
Ok, so you know the idea..you click on a character's arm..it selects the character..you click again, and the arm is selected.
That's stopped working.
I quit and restarted the program, but that didn't fix it.
anyone see something like this before?
  • RedzRedz Posts: 1,459
    Just a thought. Are you using the correct tool? For example if you are using scene navigator, you can't select parts, but with the universal tool and others you can.
  • ScavengerScavenger Posts: 2,677
    edited November 2015
    ...yes..I was using the right tool.
    I found the problem.  A setting in Tool Settings got changed from Root Node first to Root Node Only
    526 x 427 - 61K
    Post edited by Scavenger on
    Ah glad you found the solution. :)
