The Quick Grab changed over at the right time. However, is the pricing correct? $9.99/$4.99 is usually bundles, but today it's items that are usually 1 or 2 tiers lower - hairs, clothing, shaders, alt shapes, environments, even https://www.daz3d.com/victoria-9-hd.
Shouldn't owning the lime product give you the discount automatically since you can't add it to your cart? You can add it while logged out but gets removed when you log in.
Looking at the qualifying DAZ Originals for the CINCO-BABY coupon, around forty Genesis 9 bundles have been removed/deactivated already. Is this a mistake?
I'm not seeing any discount from the Lime at all. I have it in my cart but there's no extra 5% off my other items (which are not New Releases, Daz+, etc.). I also don't see the 15% discount if I add a New Release
Do you have an onsite? If you don't and own it, you'll likely need to do a ticket.
Those bundles date from before Daz reorganized core figure into "character bundle" and "add-on bundle", it's normal that they're inactive as they've been replaced by character/add-on bundles.
They probably shouldn't appear in that category however.
edit: I just noticed that the button simply links to all Daz Originals, which probably explains why they're listed.
I don't own it. I am just adding it to the cart as normal as part of the Cinco de Mayo offer. The lime is free but nothing in my cart changes price (with or without New Release over $1).
The only discount I'm seeing is laughable. Testing with Gabriela 8 Pro BUndle. The price drops from $135.95 to $135.41 . That's a $0.54 discount for owning the cinco de lime-o.
If you already own the lime-o you should have an orange banner with a coupon code.
Would you please screenshot your cart and I'll try to rebuild it on my end?
Oh, okay. I didn't notice getting a banner. Checking the message inbox gives me a coupon code with a higher discount. My mistake.
Couldn't try Gabriela as I own the bundle, but tried a different item and got the expected discount.
I didn't exactly have a set cart it wasn't working on (it didn't work for anything I added to my cart). But here's a cart with some of the things I tried in it.
I have no idea why I'm getting a 50-cent discount with the pro bundle.
Yes, I am aware, but the point is that if Daz is going to link ot a selection of items that go with a code, they should be the ones that actually work with the code. The customer shouldn't need an extra 3rd party solution to achieve that result. (Especially since the vast majority of customers are not active on the forums, and therefore likely don't know about the bookmarklet.)
Should work now.
The cinco de mayo graphic takes you back to the shop home page
Reported
Ok, working now.
Thank you.
There is an inactive product among the new releases:
https://www.daz3d.com/v8-unitard-for-genesis-8-female
https://www.daz3d.com/happy-cinco-de-mayo#debut_new
Can't take advantage of the extra 15% off offer as I already own item:
FREE Cinco de Lime-O
Extra 5% off your cart with Cinco de Lime-O
Extra 15% off your cart with Cinco de Lime-O
and a New Release over $1
It was not meant to be there.
You should have an onsite if you own it.
Emmet for Eduardo, which is also in the CINCO-BABY category, has a "NaN" price and can't be added to the cart
CINCO-BABY button leads to a selection including D+, even though D+ is excluded by the fine print.
Selection should be modified to only include items that are eligible.
I can't find a single item which you could apply the CINCO-BABY code.
Oh, just saw this, let me try.
It simply links to all Daz Originals currently.
In case you haven't seen it, there's a free bookmarklet which adds extra filters to the shop, including a "hide Daz+" one: https://www.daz3d.com/forums/discussion/742841/extra-shop-filters-bookmarklet#latest
Reported: the expected discount is triggered with the new release, but no discount appears with only the lime.
Is this supposed to overrule this?
Because I put https://www.daz3d.com/mexico-city in my cart and it says 80% in the cart even though the lime and a new release are in the cart.
