Character looses reference to correct Powerpose template
I have a couple of times the last days, had a character (G8F) loose the reference to which Powerpose template it uses, and I get a generic.
Restart will usually fix it, but closing a scene and reopen takes some time.
In scene identification everything looks normal.
Are there any options for fixing it in Daz Studio (instead of restart), or have somebody any ideas for what can cause it.
  • NorthOf45NorthOf45 Posts: 5,889
    Which version of Studio? PowerPose is a bit of a mystery, since we can't see the actual contents of the encrypted templates. From my experiences, the PowerPose code looks for the node name (not the node label) to select the templates to use.
    Are you using the DAZ templates, or have you tried my alternatives Alternative PowerPose Templates (Genesis 1, 2, 3, 8, 8.1, 9)? They probably won't help with any Studio coding problems, if that's the case, but they are different. They work properly on DS 4.24 and 6.25.
  • felisfelis Posts: 6,493
    I am using the 4.24 beta and Daz Studio templates.
    Can try your templates, and see if it makes a difference. But it is hard to test, as I don't know what triggers it. And I don't know what can cause a character to change or loose node name, when I am just posing the character.
  • garrett_3dgarrett_3d Posts: 841
    Have you tried upgrading to the general release version of 4.24? Can't understand why people would still use a beta version so long after release.
    I have both Beta and general. But all my customization is primarily in the Beta.. And they should work the same
    I see what you are saying. However, it's common knowledge that any beta release will contain a certain amount of bugs. This applies to any software. Beta releases are not ideal for normal use.
    A Beta release is a release candidate, and when approved it will be released as an official version.
    And as development in DS 4 is stopped there is no new changes. And as can be seen as both versions has the same release number 4.24.0.4.
